Razer Naga Trinity Scroll Wheel Housing Replacement
  1. Razer Naga Trinity Scroll Wheel Housing Replacement, Razer Naga Trinity Disassembly: step 1, image 1 of 2 Razer Naga Trinity Scroll Wheel Housing Replacement, Razer Naga Trinity Disassembly: step 1, image 2 of 2
    • Remove the interchangeable side plate.
    Ask FixBot
  2. Razer Naga Trinity Scroll Wheel Housing Replacement: step 2, image 1 of 2 Razer Naga Trinity Scroll Wheel Housing Replacement: step 2, image 2 of 2
    • Remove the mouse's feet using the opening pick.
    Ask FixBot
  3. Razer Naga Trinity Scroll Wheel Housing Replacement: step 3, image 1 of 1
    • Remove the four 6mm screws by using a JIS #1 screwdriver.
    Ask FixBot
  4. Razer Naga Trinity Scroll Wheel Housing Replacement: step 4, image 1 of 2 Razer Naga Trinity Scroll Wheel Housing Replacement: step 4, image 2 of 2
    • Separate the top mouse housing from the bottom mouse housing using the opening pick.
    • Be careful not to tug too hard on the ribbon connector.
    Ask FixBot
  5. Razer Naga Trinity Scroll Wheel Housing Replacement: step 5, image 1 of 1
    • Unlock the ribbon connector that is held down by the main board clips using the spudger's pointed end.
    Ask FixBot
  6. Razer Naga Trinity Scroll Wheel Housing Replacement: step 6, image 1 of 1
    • Remove the side housing using the opening pick.
    Ask FixBot
  7. Razer Naga Trinity Scroll Wheel Housing Replacement: step 7, image 1 of 2 Razer Naga Trinity Scroll Wheel Housing Replacement: step 7, image 2 of 2
    • Remove the top housing LED 3-Pin connector that is near the main board.
    Ask FixBot
  8. Razer Naga Trinity Scroll Wheel Housing Replacement, Scroll Wheel Housing: step 8, image 1 of 2 Razer Naga Trinity Scroll Wheel Housing Replacement, Scroll Wheel Housing: step 8, image 2 of 2
    • Remove one 4mm black Phillips #000 screw from the left side of the mouse holding the scroll wheel LED controller board.
    • Then pull the LED controller board upwards and out.
    Ask FixBot
  9. Razer Naga Trinity Scroll Wheel Housing Replacement: step 9, image 1 of 1
    Tool used on this step:
    Halberd Spudger
    $2.99
    Buy
    • Pry and remove the scroll wheel feedback bar from its hold-down clips using the hook end of a halberd spudger.
    Ask FixBot
  10. Razer Naga Trinity Scroll Wheel Housing Replacement: step 10, image 1 of 1
    $3.99
    Buy
    • Remove the scroll wheel feedback bar from the scroll wheel by holding down the spring and using angled tweezers to remove it from its placement.
    Ask FixBot
  11. Razer Naga Trinity Scroll Wheel Housing Replacement: step 11, image 1 of 2 Razer Naga Trinity Scroll Wheel Housing Replacement: step 11, image 2 of 2
    • Remove the scroll wheel optical encoder 3-pin connector from the main board by wiggling the connector upwards.
    Ask FixBot
  12. Razer Naga Trinity Scroll Wheel Housing Replacement: step 12, image 1 of 3 Razer Naga Trinity Scroll Wheel Housing Replacement: step 12, image 2 of 3 Razer Naga Trinity Scroll Wheel Housing Replacement: step 12, image 3 of 3
    • Using the opening tool, pry the black bracket holding the scroll wheel in place backwards until the scroll wheel housing pops out.
    Ask FixBot
2 other people completed this guide.
Kristen Gismondi
107,794 Reputation
270 Guides authored
iFixit Member of iFixit
Staff
123 Members
28,230 Guides authored
2 Guide Comments
can you give a link for a replacement scroll wheel if possible?
joe - Reply Share
nice guide but i sadly didn’t found any housing wheel replacement part ><
Zzz Zzz - Reply Share
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 85
All Time: 6,533
