Razer Naga Trinity LED Light Ribbon Cable Replacement
    1. Razer Naga Trinity LED Light Ribbon Cable Replacement, Razer Naga Trinity Disassembly: step 1, image 1 of 2 Razer Naga Trinity LED Light Ribbon Cable Replacement, Razer Naga Trinity Disassembly: step 1, image 2 of 2
      • Remove the interchangeable side plate.
      Ask FixBot
    2. Razer Naga Trinity LED Light Ribbon Cable Replacement: step 2, image 1 of 2 Razer Naga Trinity LED Light Ribbon Cable Replacement: step 2, image 2 of 2
      • Remove the mouse's feet using the opening pick.
      Ask FixBot
    3. Razer Naga Trinity LED Light Ribbon Cable Replacement: step 3, image 1 of 1
      • Remove the four 6mm screws by using a JIS #1 screwdriver.
      Ask FixBot
    4. Razer Naga Trinity LED Light Ribbon Cable Replacement: step 4, image 1 of 2 Razer Naga Trinity LED Light Ribbon Cable Replacement: step 4, image 2 of 2
      • Separate the top mouse housing from the bottom mouse housing using the opening pick.
      • Be careful not to tug too hard on the ribbon connector.
      Ask FixBot
    5. Razer Naga Trinity LED Light Ribbon Cable Replacement: step 5, image 1 of 1
      • Unlock the ribbon connector that is held down by the main board clips using the spudger's pointed end.
      Ask FixBot
    6. Razer Naga Trinity LED Light Ribbon Cable Replacement: step 6, image 1 of 1
      • Remove the side housing using the opening pick.
      Ask FixBot
    7. Razer Naga Trinity LED Light Ribbon Cable Replacement: step 7, image 1 of 2 Razer Naga Trinity LED Light Ribbon Cable Replacement: step 7, image 2 of 2
      • Remove the top housing LED 3-Pin connector that is near the main board.
      Ask FixBot
    1. Razer Naga Trinity LED Light Ribbon Cable Replacement, LED Light Ribbon Cable: step 8, image 1 of 2 Razer Naga Trinity LED Light Ribbon Cable Replacement, LED Light Ribbon Cable: step 8, image 2 of 2
      • Using the flat end of a spudger, unlock the ribbon cable holding the clips.
      • Remove the ribbon cable.
      Ask FixBot
1 Guide Comment
Hi, I am having an issue where my mouse works completely fine except for led / tracking...
Every button works left click right click, scroll & DPI / Profile buttons are completely fine... But tacking and moving my cursor doesn't work... or at least not well enough to be used !
When I change surface or when I open my computer it sometimes works for about 5 seconds but as soon as I lift it even the slightest bit it just stops working no movement anymore... ! And sometimes spaming my Dpi button works or opening Razer Synapse but it never lasts more than 5-10 secondes maybe pushing 15 then it just stops.
My question is, is there any way to fix this issue / does replacing the Led Light Ribbon fix this :) ?
Thank you so much in advance,
Francis.
Mlizu - Reply Share
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 35
All Time: 2,345
