Razer Naga Expert MMO Top Plastic Shell Replacement
  1. Razer Naga Expert MMO Top Plastic Shell Replacement, Top Plastic Shell: step 1, image 1 of 1
    • Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
    Ask FixBot
  2. Razer Naga Expert MMO Top Plastic Shell Replacement: step 2, image 1 of 1
    • Remove the four 7mm screws using a Phillips #00 screwdriver.
    Ask FixBot
  3. Razer Naga Expert MMO Top Plastic Shell Replacement: step 3, image 1 of 1
    • Gently remove the top plastic plate of the mouse.
    • Unplug the white cord from the circuit board.
    Ask FixBot
  4. Razer Naga Expert MMO Top Plastic Shell Replacement: step 4, image 1 of 1
    • Lightly pull the two plastic sides of the mouse to remove them.
    Ask FixBot
5 other people completed this guide.
2 Guide Comments
do you know where i can get a new top body section? i have a molten that stopped left clicking on every click, i opened it up and the plastic pretty much was worn away
pipsqueak642 - Reply Share
i’m after the rubber adhesive for the side of this mouse if any one knows where to buy it from cheers.
mayo22 - Reply Share
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 63
All Time: 2,645
