Introduction
Go to step 1 ↓This guide will help you replace the connection strip between the side buttons on the outer casing and the mouse itself. Be sure to use caution when unplugging the wires, for this could result in the mouse not working properly. Also use caution when removing the plastic shell, it is fragile and it could be cracked upon removal.
Tools
Spudger4.9
Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
Flip back the black plastic that holds the white connection strip in place on the side panel and the main panel.
2 Guide Comments
What is the code for the connection strip and how many pins does it have?
Thank you for the guide.
This is not always necessary to replace the fiber cable, in my case removing the Razer Software on Desktop helped to fix the button lags.
