Razer Naga Expert MMO Cable Replacement
  1. Razer Naga Expert MMO Cable Replacement, Top Plastic Shell: step 1, image 1 of 1
    • Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
    Ask FixBot
  2. Razer Naga Expert MMO Cable Replacement: step 2, image 1 of 1
    • Remove the four 7mm screws using a Phillips #00 screwdriver.
    Ask FixBot
  3. Razer Naga Expert MMO Cable Replacement: step 3, image 1 of 1
    • Gently remove the top plastic plate of the mouse.
    • Unplug the white cord from the circuit board.
    Ask FixBot
  4. Razer Naga Expert MMO Cable Replacement: step 4, image 1 of 1
    • Lightly pull the two plastic sides of the mouse to remove them.
    Ask FixBot
  5. Razer Naga Expert MMO Cable Replacement, Scroll Wheel: step 5, image 1 of 1
    • Using a Phillips #00 screwdriver, remove the 5mm screw holding the scroll wheel in place.
    Ask FixBot
  6. Razer Naga Expert MMO Cable Replacement: step 6, image 1 of 1
    • Unplug the cord that connects the scroll wheel to the motherboard.
    Ask FixBot
  7. Razer Naga Expert MMO Cable Replacement: step 7, image 1 of 1
    • Slide the chip out of the scroll wheel.
    Ask FixBot
  8. Razer Naga Expert MMO Cable Replacement: step 8, image 1 of 2 Razer Naga Expert MMO Cable Replacement: step 8, image 2 of 2
    • Gently wiggle the scroll wheel up and back to remove the scroll wheel from the mouse.
    • Use your fingers to simultaneously push the scroll wheel and its frame forward and pull back on the plastic tab directly behind the scroll wheel until it is loose.
    • Use your thumbs to pop the scroll wheel out from its plastic frame.
    Ask FixBot
  9. Razer Naga Expert MMO Cable Replacement: step 9, image 1 of 1
    • Place the new scroll wheel in the mount.
    • Upon reassembly, be careful to ensure the silver box on the side of the wheel is placed into the frame with the tab facing downward so upon entry into the frame it fits into its slot.
    Ask FixBot
  10. Razer Naga Expert MMO Cable Replacement, Motherboard: step 10, image 1 of 1
    • Using a Phillips #00 screwdriver, remove all five 5mm screws that connect the motherboard to the main frame.
    Ask FixBot
  11. Razer Naga Expert MMO Cable Replacement: step 11, image 1 of 2 Razer Naga Expert MMO Cable Replacement: step 11, image 2 of 2
    • Place the new motherboard in the mouse.
    • When reassembling the mouse, place the loose plastic piece that holds the scroll wheel and wire in place into the rectangular slots in the circuit board.
    Ask FixBot
  12. Razer Naga Expert MMO Cable Replacement, Cable: step 12, image 1 of 1
    • Once the motherboard is removed, pull the wire out of the plastic grooves on the bottom shell.
    • Then to completely detach the cable, unplug its white connection port from the motherboard.
    Ask FixBot
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 69
All Time: 3,687
