Introduction
This guide will show you how to replace a broken or malfunctioning connection strip. Before attempting the process in this guide, be sure to check that your mouse's drivers are up to date, the mouse's buttons are already connected properly and there are no other issues.
There will also be instructions on how to remove and replace a "swollen" or otherwise damaged battery, as the battery will be removed in order to reach the connection strip.
Exercise caution while following the procedure to avoid damaging other components. Additionally, be sure to handle the battery carefully, as a swollen battery is subject to combustion if punctured or subjected to extreme temperatures or other conditions.
Using a spudger, remove the teflon tape on the bottom of the mouse to reveal four screws.
Take your nylon spudger to gently pry the battery pack from the device.
Remove the foam on the battery shell for your new battery.
Under the battery, remove the two screws holding the battery mount in place.
Remove the battery mount.
To reassemble your device, follow these instructions in reverse order. Test your mouse to ensure the connection strip is set up correctly; if not, go back and make sure that all of the wires were re-connected successfully.
