Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement
    1. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement, Scroll Wheel Encoder: step 1, image 1 of 1
      • Peel back the two teflon pads from the top corners and the one larger one from the bottom with the help of a spudger.
      • You will find four 7 mm screws under the teflon pads.
      Ask FixBot
    2. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: step 2, image 1 of 1
      • Remove the four 7mm screws using a Phillips #00 screwdriver.
      Ask FixBot
    3. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: step 3, image 1 of 2 Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: step 3, image 2 of 2
      • Gently remove the top plastic shell from the mouse.
      • Be careful when lifting the shell up to avoid damage to the cable connected to the board and shell.
      • The top shell is separate from the sides of the mouse.
      • Unplug the cable coming from the top shell that connects to the board.
      Ask FixBot
    4. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: step 4, image 1 of 1
      • Gently pull the two plastic sides off the mouse.
      • Pry the sides off gently so you don't crack any of the plastic tabs that hold them in place.
      Ask FixBot
    5. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: step 5, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the 5 mm screw holding the scroll wheel in place.
      • This screw is different than the ones at the bottom of the mouse so keep it separate.
      Ask FixBot
    6. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: step 6, image 1 of 1
      • Unplug the cord that connects the scroll wheel to the motherboard.
      Ask FixBot
    7. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: step 7, image 1 of 1
      • Gently slide the lighting chip up and out of the scroll wheel.
      Ask FixBot
    8. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: step 8, image 1 of 1
      • Use a spudger to gently pry the scroll wheel assembly out from the plastic housing.
      Ask FixBot
    9. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: step 9, image 1 of 1
      • Remove the scroll wheel from the holder by pushing it up from underneath.
      Ask FixBot
    10. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: step 10, image 1 of 1
      • Remove the old encoder chip and replace with the new one.
      • Make sure that the silver part of the encoder faces out and that the small square points down when reinstalling.
      Ask FixBot
Tony Di Folca
231 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 82
All Time: 3,406
