Razer Kishi v2 Pro Front Panel Replacement
  1. Razer Kishi v2 Pro Front Panel Replacement, Front Panel: step 1, image 1 of 1
    • Put the device down with the bottom facing up.
    • Remove the eight 12 mm screws from the back of the controller using a T5 screwdriver.
    Ask FixBot
  2. Razer Kishi v2 Pro Front Panel Replacement: step 2, image 1 of 3 Razer Kishi v2 Pro Front Panel Replacement: step 2, image 2 of 3 Razer Kishi v2 Pro Front Panel Replacement: step 2, image 3 of 3
    • Gently apply light pressure to the front top half of the controller and slowly lift it up.
    • When you hear a click, the two halves should be successfully disconnected.
    • When you separate the two parts from each other, two of the back bumpers might fall out. If the bumpers do fall out don't worry because they just snap back in.
    • Be careful when doing this, if you apply too much pressure you could rip the ribbon cable.
    • Repeat for the opposite side of the controller.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 42
All Time: 484
