Razer Kishi Face Buttons Replacement
  1. Razer Kishi Face Buttons Replacement, Remove the screws: step 1, image 1 of 1
    • The opening process is the same on both sides. For simplicity, this guide shows only the right-side opening process. Unscrew whichever side you wish to open and work on.
    • For the right side, remove the five Y0 screws securing the right side of the controller.
    • Four 9.2 mm screws
    • One 7.2 mm screw
    • If you wish to open the left side, remove the five Y0 screws securing the left side of the controller.
    • One 7.2 mm screw
    Ask FixBot
  2. Razer Kishi Face Buttons Replacement, Release the bottom edge clips: step 2, image 1 of 3 Razer Kishi Face Buttons Replacement, Release the bottom edge clips: step 2, image 2 of 3 Razer Kishi Face Buttons Replacement, Release the bottom edge clips: step 2, image 3 of 3
    • Both cases are held together by plastic clips.
    • Insert an opening pick in the seam between the top and bottom case, at the bottom left corner of the controller.
    • With the pick still in the seam, slide it along the bottom edge to the bottom right corner to loosen the plastic clips.
    Ask FixBot
  3. Razer Kishi Face Buttons Replacement, Release the side edge clips: step 3, image 1 of 2 Razer Kishi Face Buttons Replacement, Release the side edge clips: step 3, image 2 of 2
    • Slide the opening pick along the right edge to loosen the plastic clips.
    Ask FixBot
  4. Razer Kishi Face Buttons Replacement, Release the top edge clips: step 4, image 1 of 2 Razer Kishi Face Buttons Replacement, Release the top edge clips: step 4, image 2 of 2
    • Slide the opening pick along the top edge to loosen the remaining plastic clips.
    • Don't try to remove the top side yet, the case is still connected to the board.
    Ask FixBot
  5. Razer Kishi Face Buttons Replacement: step 5, image 1 of 3 Razer Kishi Face Buttons Replacement: step 5, image 2 of 3 Razer Kishi Face Buttons Replacement: step 5, image 3 of 3
    • Carefully lift the top side and unfold it to the right, like a book.
    Ask FixBot
  6. Razer Kishi Face Buttons Replacement, Disconnect the interconnect cable: step 6, image 1 of 3 Razer Kishi Face Buttons Replacement, Disconnect the interconnect cable: step 6, image 2 of 3 Razer Kishi Face Buttons Replacement, Disconnect the interconnect cable: step 6, image 3 of 3
    • Using the pointed end of a spudger, push the grey tabs on the interconnect socket away from the socket, parallel to the interconnect cable, to release the cable.
    • Pull the cable out of the socket.
    Ask FixBot
  7. Razer Kishi Face Buttons Replacement, Remove the screws: step 7, image 1 of 1
    • Use a Phillips #0 screwdriver to remove the two 4.4 mm-long screws securing the trigger board.
    Ask FixBot
  8. Razer Kishi Face Buttons Replacement, Remove the breakout board: step 8, image 1 of 3 Razer Kishi Face Buttons Replacement, Remove the breakout board: step 8, image 2 of 3 Razer Kishi Face Buttons Replacement, Remove the breakout board: step 8, image 3 of 3
    • The breakout board is plugged in. When removing breakout board, it is important to pull it straight out to avoid bending the connectors.
    • Remove the breakout board by lifting it straight up, away from the controller.
    Ask FixBot
  9. Razer Kishi Face Buttons Replacement, Remove the screws: step 9, image 1 of 1
    • Use a Phillips #0 screwdriver to remove the two 7.0 mm-long screws securing the trigger.
    Ask FixBot
  10. Razer Kishi Face Buttons Replacement, Remove the trigger: step 10, image 1 of 2 Razer Kishi Face Buttons Replacement, Remove the trigger: step 10, image 2 of 2
    • Remove the shoulder trigger.
    Ask FixBot
  11. Razer Kishi Face Buttons Replacement, Lift the shoulder button board: step 11, image 1 of 2 Razer Kishi Face Buttons Replacement, Lift the shoulder button board: step 11, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of blunt nose tweezers to lift out the shoulder button board.
    Ask FixBot
  12. Razer Kishi Face Buttons Replacement, Remove the screws: step 12, image 1 of 1
    • Use a Phillips #0 screwdriver to remove the two 5.9 mm-long screws.
    Ask FixBot
  13. Razer Kishi Face Buttons Replacement, Remove the board: step 13, image 1 of 2 Razer Kishi Face Buttons Replacement, Remove the board: step 13, image 2 of 2
    • Pull the mainboard straight out of the frame to remove it.
    Ask FixBot
  14. Razer Kishi Face Buttons Replacement, Pull off the rubber cover: step 14, image 1 of 3 Razer Kishi Face Buttons Replacement, Pull off the rubber cover: step 14, image 2 of 3 Razer Kishi Face Buttons Replacement, Pull off the rubber cover: step 14, image 3 of 3
    • Remove the rubber cover by pulling it upwards.
    Ask FixBot
  15. Razer Kishi Face Buttons Replacement, Remove the face buttons: step 15, image 1 of 2 Razer Kishi Face Buttons Replacement, Remove the face buttons: step 15, image 2 of 2
    Buy
    • Use a pair of tweezers to remove the face buttons.
    Ask FixBot
Adriana Zwink
67,627 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
123 Members
27,603 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 28
All Time: 2,637
