Razer Kishi Bumper Replacement
  1. Razer Kishi Bumper Replacement, Remove the screws: step 1, image 1 of 1
    • The opening process is the same on both sides. For simplicity, this guide shows only the right-side opening process. Unscrew whichever side you wish to open and work on.
    • For the right side, remove the five Y0 screws securing the right side of the controller.
    • Four 9.2 mm screws
    • One 7.2 mm screw
    • If you wish to open the left side, remove the five Y0 screws securing the left side of the controller.
    • One 7.2 mm screw
    Ask FixBot
  2. Razer Kishi Bumper Replacement, Release the bottom edge clips: step 2, image 1 of 3 Razer Kishi Bumper Replacement, Release the bottom edge clips: step 2, image 2 of 3 Razer Kishi Bumper Replacement, Release the bottom edge clips: step 2, image 3 of 3
    • Both cases are held together by plastic clips.
    • Insert an opening pick in the seam between the top and bottom case, at the bottom left corner of the controller.
    • With the pick still in the seam, slide it along the bottom edge to the bottom right corner to loosen the plastic clips.
    Ask FixBot
  3. Razer Kishi Bumper Replacement, Release the side edge clips: step 3, image 1 of 2 Razer Kishi Bumper Replacement, Release the side edge clips: step 3, image 2 of 2
    • Slide the opening pick along the right edge to loosen the plastic clips.
    Ask FixBot
  4. Razer Kishi Bumper Replacement, Release the top edge clips: step 4, image 1 of 2 Razer Kishi Bumper Replacement, Release the top edge clips: step 4, image 2 of 2
    • Slide the opening pick along the top edge to loosen the remaining plastic clips.
    • Don't try to remove the top side yet, the case is still connected to the board.
    Ask FixBot
  5. Razer Kishi Bumper Replacement: step 5, image 1 of 3 Razer Kishi Bumper Replacement: step 5, image 2 of 3 Razer Kishi Bumper Replacement: step 5, image 3 of 3
    • Carefully lift the top side and unfold it to the right, like a book.
    Ask FixBot
  6. Razer Kishi Bumper Replacement, Disconnect the interconnect cable: step 6, image 1 of 3 Razer Kishi Bumper Replacement, Disconnect the interconnect cable: step 6, image 2 of 3 Razer Kishi Bumper Replacement, Disconnect the interconnect cable: step 6, image 3 of 3
    • Using the pointed end of a spudger, push the grey tabs on the interconnect socket away from the socket, parallel to the interconnect cable, to release the cable.
    • Pull the cable out of the socket.
    Ask FixBot
  7. Razer Kishi Bumper Replacement, Remove the screws: step 7, image 1 of 1
    • Use a Phillips #0 screwdriver to remove the two 4.4 mm-long screws securing the trigger board.
    Ask FixBot
  8. Razer Kishi Bumper Replacement, Remove the breakout board: step 8, image 1 of 3 Razer Kishi Bumper Replacement, Remove the breakout board: step 8, image 2 of 3 Razer Kishi Bumper Replacement, Remove the breakout board: step 8, image 3 of 3
    • The breakout board is plugged in. When removing breakout board, it is important to pull it straight out to avoid bending the connectors.
    • Remove the breakout board by lifting it straight up, away from the controller.
    Ask FixBot
  9. Razer Kishi Bumper Replacement, Remove the screws: step 9, image 1 of 1
    • Use a Phillips #0 screwdriver to remove the two 7.0 mm-long screws securing the trigger.
    Ask FixBot
  10. Razer Kishi Bumper Replacement, Remove the trigger: step 10, image 1 of 2 Razer Kishi Bumper Replacement, Remove the trigger: step 10, image 2 of 2
    • Remove the shoulder trigger.
    Ask FixBot
  11. Razer Kishi Bumper Replacement, Remove the metal pin: step 11, image 1 of 2 Razer Kishi Bumper Replacement, Remove the metal pin: step 11, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of tweezers to remove the metal pin which holds the bumper in its place.
    Ask FixBot
  12. Razer Kishi Bumper Replacement, Remove the bumper: step 12, image 1 of 2 Razer Kishi Bumper Replacement, Remove the bumper: step 12, image 2 of 2
    • Use your fingers to remove the bumper.
    Ask FixBot
4 other people completed this guide.
Adriana Zwink
67,717 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
123 Members
28,236 Guides authored
4 Guide Comments
I can't remove the left shell of the controller. It seems to be either glued down or won't snap off. I'm worried that I would break the shell or even worse, the motherboard inside. Please help because this has been broken since December of last year and I have the tools to fix it and don't want to spend money to buy a new one.
Punkie Spam - Reply Share
Where did you buy the spare part you want to replace?
ZettoBoi - Reply Share
Saved me! Was able to get the right trigger to reattach with the high res images!
Jose Cantu Jr - Reply Share
Hellooo
Unfortunately the trigger on the right is broken for me.
Can anybody say me where i can buy this spare part?
Thanks ☺️
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 46
All Time: 2,539
