Razer Hydra Joystick Cover Replacement
  1. Razer Hydra Joystick Cover Replacement, Joystick Cover: step 1, image 1 of 3 Razer Hydra Joystick Cover Replacement, Joystick Cover: step 1, image 2 of 3 Razer Hydra Joystick Cover Replacement, Joystick Cover: step 1, image 3 of 3
    • Use the pointed end of a spudger to remove the three rubber ends that cover three screws.
    Ask FixBot
  2. Razer Hydra Joystick Cover Replacement: step 2, image 1 of 3 Razer Hydra Joystick Cover Replacement: step 2, image 2 of 3 Razer Hydra Joystick Cover Replacement: step 2, image 3 of 3
    • Use a Phillips screwdriver to remove the three screws.
    Ask FixBot
  3. Razer Hydra Joystick Cover Replacement: step 3, image 1 of 2 Razer Hydra Joystick Cover Replacement: step 3, image 2 of 2
    • Hold onto the bottom of the controller, and slide the top shell off.
    Ask FixBot
  4. Razer Hydra Joystick Cover Replacement: step 4, image 1 of 3 Razer Hydra Joystick Cover Replacement: step 4, image 2 of 3 Razer Hydra Joystick Cover Replacement: step 4, image 3 of 3
    • Slowly pull up the black locking tab connector attached to the ribbon cable.
    • BE CAREFUL! This black piece does not come off. Only lift it so that it is not holding the ribbon cable.
    Ask FixBot
  5. Razer Hydra Joystick Cover Replacement: step 5, image 1 of 2 Razer Hydra Joystick Cover Replacement: step 5, image 2 of 2
    • Separate the ribbon cable from the housing.
    Ask FixBot
  6. Razer Hydra Joystick Cover Replacement: step 6, image 1 of 3 Razer Hydra Joystick Cover Replacement: step 6, image 2 of 3 Razer Hydra Joystick Cover Replacement: step 6, image 3 of 3
    • Use a Phillips screwdriver to remove the two screws securing the joystick PCB to the case.
    Ask FixBot
  7. Razer Hydra Joystick Cover Replacement: step 7, image 1 of 2 Razer Hydra Joystick Cover Replacement: step 7, image 2 of 2
    • Gently remove the joystick board.
    Ask FixBot
  8. Razer Hydra Joystick Cover Replacement: step 8, image 1 of 3 Razer Hydra Joystick Cover Replacement: step 8, image 2 of 3 Razer Hydra Joystick Cover Replacement: step 8, image 3 of 3
    • Remove the two screws on the joystick board.
    Ask FixBot
  9. Razer Hydra Joystick Cover Replacement: step 9, image 1 of 3 Razer Hydra Joystick Cover Replacement: step 9, image 2 of 3 Razer Hydra Joystick Cover Replacement: step 9, image 3 of 3
    • Gently pry the black side pieces apart from both ends.
    • Remove the surface shell from the board.
    Ask FixBot
  10. Razer Hydra Joystick Cover Replacement: step 10, image 1 of 3 Razer Hydra Joystick Cover Replacement: step 10, image 2 of 3 Razer Hydra Joystick Cover Replacement: step 10, image 3 of 3
    • Firmly grip the damaged joystick and pull it from the board.
    Ask FixBot
  11. Razer Hydra Joystick Cover Replacement: step 11, image 1 of 2 Razer Hydra Joystick Cover Replacement: step 11, image 2 of 2
    • Take your new joystick part and push it back onto the bar.
    • Make sure you put it on straight in order to not damage the joystick board.
    Ask FixBot
Finish Line
Aiden Y.
193 Reputation
1 Guide authored
UC Davis, Team 1-9, Morris Spring 2025 Member of UC Davis, Team 1-9, Morris Spring 2025
UCD-MORRIS-S25S1G9
3 Members
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 33
All Time: 236
