Razer Huntsman Tournament Edition Port Replacement
  1. Razer Huntsman Tournament Edition Port Replacement, Keycaps: step 1, image 1 of 1
    • Place the unplugged keyboard on a flat, clean surface appropriate for working on.
    Ask FixBot
  2. Razer Huntsman Tournament Edition Port Replacement: step 2, image 1 of 2 Razer Huntsman Tournament Edition Port Replacement: step 2, image 2 of 2
    • Grip the keycap with your keycap puller.
    • You can remove keycaps with your fingers if you don’t have a puller, but the adjacent keycaps must be removed first for sufficient grip.
    Ask FixBot
  3. Razer Huntsman Tournament Edition Port Replacement: step 3, image 1 of 3 Razer Huntsman Tournament Edition Port Replacement: step 3, image 2 of 3 Razer Huntsman Tournament Edition Port Replacement: step 3, image 3 of 3
    • Pull with an upwards force to remove the keycap.
    • Take a moment to clean the area that was previously obscured if it’s dirty.
    • Use gentle force so as not to damage the stabilizers.
    Ask FixBot
  4. Razer Huntsman Tournament Edition Port Replacement, Chassis: step 4, image 1 of 1
    • Remove all of the keycaps with a keycap puller.
    Ask FixBot
  5. Razer Huntsman Tournament Edition Port Replacement: step 5, image 1 of 3 Razer Huntsman Tournament Edition Port Replacement: step 5, image 2 of 3 Razer Huntsman Tournament Edition Port Replacement: step 5, image 3 of 3
    • Unscrew the thirteen 6.5 mm screws, using the Phillips #0 screwdriver, that are located in the front panel.
    • Screw placement and quantity may vary per unit.
    • If you have removed all screws and the front panel cannot be removed, there may be an additional screw near the USB port, below the sticker. (See third photo)
    Ask FixBot
  6. Razer Huntsman Tournament Edition Port Replacement: step 6, image 1 of 1
    • Use an opening tool to pry open the chassis.
    • Be careful not to use excessive force during this step so the plastic doesn't warp or break.
    Ask FixBot
  7. Razer Huntsman Tournament Edition Port Replacement: step 7, image 1 of 1
    • Gently lift the front panel off.
    • The front panel should be connected to the USB board. Do not tug the panel off as this may damage other parts.
    Ask FixBot
  8. Razer Huntsman Tournament Edition Port Replacement: step 8, image 1 of 1
    • Disconnect the internal cable.
    Ask FixBot
  9. Razer Huntsman Tournament Edition Port Replacement, Port: step 9, image 1 of 2 Razer Huntsman Tournament Edition Port Replacement, Port: step 9, image 2 of 2
    • Unscrew the board with the port.
    • It should be located on the upper left, held in by two 6.5mm Phillips #0 screws.
    • Move the cable out of the way for the second screw
    Ask FixBot
  10. Razer Huntsman Tournament Edition Port Replacement: step 10, image 1 of 1
    • Detach the internal cable from the USB board.
    • Do this carefully.
    Ask FixBot
  11. Razer Huntsman Tournament Edition Port Replacement: step 11, image 1 of 1
    • Remove the USB board.
    Ask FixBot
Joseph O'Dowd
419 Reputation
3 Guides authored
1 Guide Comment
how do i get a new port and where
Guardian Suit - Reply Share
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 47
All Time: 815
