Up to 20% off select tools
Razer Huntsman TE Keycaps Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
5
Past 7 Days:
30
Past 30 Days:
97
All Time:
3,234
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 4 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The Razer Huntsman TE is one of the most widely used keyboards today, and one of the most common problems users encounter is keys getting stuck. The Razer Huntsman TE is a very different keyboard as it uses light instead of mechanical switches to send signals to the computer. This makes it far more sensitive than other keyboards. More caution is advised with each step, so as not to cause any damage to the device.
    1. Razer Huntsman TE Keycaps Replacement, Keycaps: step 1, image 1 of 2 Razer Huntsman TE Keycaps Replacement, Keycaps: step 1, image 2 of 2
      • Identify the correct type of key to replace.
      • Keys such as "Shift" and "Enter" have multiple slots, and each slot has a different shape, so be sure to pick the correct one.
      Ask FixBot
    2. Razer Huntsman TE Keycaps Replacement: step 2, image 1 of 2 Razer Huntsman TE Keycaps Replacement: step 2, image 2 of 2
      • Insert the keycap puller so that the teeth at the end of the puller sit beneath the keycap.
      • Apply enough upwards force for the keycap to pop out.
      Ask FixBot
    3. Razer Huntsman TE Keycaps Replacement: step 3, image 1 of 2 Razer Huntsman TE Keycaps Replacement: step 3, image 2 of 2
      Tool used on this step:
      Microfiber Cleaning Cloths
      $3.99
      Buy
      • Apply 91% isopropyl alcohol to microfiber cloth.
      • Wipe around the key.
      • Make sure that there is no residual stickiness on the key.
      Ask FixBot
    4. Razer Huntsman TE Keycaps Replacement: step 4, image 1 of 2 Razer Huntsman TE Keycaps Replacement: step 4, image 2 of 2
      • Position the replacement keycap above the keyslot.
      • Using your finger, apply downwards force to the keycap until you hear it snap into place.
      Ask FixBot
Use a diagnostic tool such as an online keyboard tester to test the key.
Author
with
Lucas de Castro
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 30
Past 30 Days: 97
All Time: 3,234
