Up to 20% off select tools
Razer Huntsman Mini Kickstand Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
71
All Time:
584
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
The kickstand of your Razer Huntsman Mini can become worn out over time. Replacing this part is a simple and effective way to restore the device's stability and prolong the life of your device.
This guide will walk you through the process of removing a damaged kickstand and installing a new one safely. No prior repair experience is necessary.
    1. Razer Huntsman Mini Kickstand Replacement, Kickstand: step 1, image 1 of 1
      • Turn off and unplug the device.
      • Flip the device to the back panel.
      • Locate the screws or clips that attach the device's legs.
      • They are usually located near the corners or the central support area.
      Ask FixBot
    2. Razer Huntsman Mini Kickstand Replacement: step 2, image 1 of 1
      • Locate the clips on both sides of the kickstand that keep it in place.
      • Carefully lift and slide out the kickstand.
      • If the kickstand is stuck, use a plastic pry tool to loosen it.
      • Avoid using excessive force to prevent damaging the device.
      Ask FixBot
    3. Razer Huntsman Mini Kickstand Replacement: step 3, image 1 of 1
      • Once the old kickstand has been removed, clean the space using a soft cloth or cotton swab.
      • Do not use soap or harsh chemicals to clean the device.
      • Take the new kickstand and align it with the mounting hole found on the sides. Snap the kickstand firmly into place.
      • Check that the new kickstand is level and secure.
      Ask FixBot
Author
with
Richm419
97 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 71
All Time: 584
