Razer Huntsman Elite Gaming Keyboard Volume Knob Repair
  1. Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Overhead View: step 1, image 1 of 1
    • Top view of the keyboard.
    Ask FixBot
  2. Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Remove Key Caps: step 2, image 1 of 1
    • Remove all key caps by pulling them directly upwards.
    Ask FixBot
  3. Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Remove All Front Screws: step 3, image 1 of 2 Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Remove All Front Screws: step 3, image 2 of 2
    • There are 18 JIS-1 screws in-between key switches. Remove all screws (see red circles). Be extremely careful if using a Phillips-1 instead of a JIS-1 as Phillips screwdrivers can destroy JIS screws.
    Ask FixBot
  4. Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Remove All Back Screws: step 4, image 1 of 2 Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Remove All Back Screws: step 4, image 2 of 2
    • Under the six rubber pads are eight JIS-1 screws that need to be removed. The edges of the pads can be lifted to access the screws without having to remove the entire pad. Using a small flat-blade screw driver can help with lifting the corner(s).
    Ask FixBot
    • Gently pry the black cover up away from the main body. Be careful not to damage the wires.
    • I apparently forgot to take pictures of this step.
    Ask FixBot
  5. Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Remove LED Light Logic Board Screws: step 6, image 1 of 3 Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Remove LED Light Logic Board Screws: step 6, image 2 of 3 Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Remove LED Light Logic Board Screws: step 6, image 3 of 3
    • Nine JIS-1 screws secure the back LED logic board. Remove all of them.
    • The back LED logic board is connected to the main PCB by a cable. Carefully disconnect the cable.
    Ask FixBot
  6. Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Pry Open the Plastic Panel: step 7, image 1 of 1
    • The transparent plastic gasket is tightly locked to the main frame via small plastic tabs all around the outside edge. Use the jimmy tool to carefully remove the panel.
    Ask FixBot
  7. Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Remove Main Frame Screws: step 8, image 1 of 2 Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Remove Main Frame Screws: step 8, image 2 of 2
    • There are three tiny JIS-000 screws that keep the main frame and the printed circuit board together. Remove the red circled screws before you separate them.
    Ask FixBot
  8. Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Disconnect Printed Circuit Board (PCB) Board Cables: step 9, image 1 of 2 Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Disconnect Printed Circuit Board (PCB) Board Cables: step 9, image 2 of 2
    • There are two cables connected to the PCB. Carefully separate the main frame and the PCB, then disconnect the lower cable first.
    • With the lower cable disconnected, the PCB can be flipped upright so as to easily remove the upper cable.
    Ask FixBot
  9. Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Logical Board: step 10, image 1 of 1
    • Now the logic board is revealed and can be cleaned up.
    Ask FixBot
  10. Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Disconnect the Flat Flexible Cable from the volume knob assembly: step 11, image 1 of 2 Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Disconnect the Flat Flexible Cable from the volume knob assembly: step 11, image 2 of 2
    • Disconnect the FFC from the volume knob assembly by retracting the black retaining clip from the white connector body and then pull the FFC out of the connector.
    • Be very gentle when handling the FFC!
    Ask FixBot
  11. Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Remove screw securing the volume knob carrier assembly: step 12, image 1 of 2 Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Remove screw securing the volume knob carrier assembly: step 12, image 2 of 2
    • There are two JIS-000 screws here but only the left one needs to be removed.
    • Note: The pictures beyond this point will show that I have removed both screws and the daughter board. I didn't realize at the time that it is unnecessary to remove the daughter board.
    Ask FixBot
  12. Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Remove volume knob carrier assembly from the main body: step 13, image 1 of 3 Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Remove volume knob carrier assembly from the main body: step 13, image 2 of 3 Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Remove volume knob carrier assembly from the main body: step 13, image 3 of 3
    • After confirming the FFC is disconnected and safely nudged out of the way, gently apply a completely vertical lifting force on the volume knob carrier assembly. Be very careful not to damage the two smaller plastic guide pins on the left side.
    • Note the orientation of the mute button icon in relation to the large guide pin holes on the left side. This will be important to remember during re-assembly.
    Ask FixBot
  13. Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Remove knob assembly from knob assembly carrier: step 14, image 1 of 1
    • There are two JIS-000 screws holding the knob assembly to the knob carrier. Remove them both.
    • Note: The mute button will now be loose and will fall out of the knob assembly. Store it safely off to the side for later re-assembly.
    Ask FixBot
  14. Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Remove PCB and encoder from knurled outer ring: step 15, image 1 of 2 Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Remove PCB and encoder from knurled outer ring: step 15, image 2 of 2
    • CAUTION: This is where things get dicey so be extra careful from here on out.
    • There are two obscured JIS-000 screws holding the PCB assembly to the knurled outer ring. Notice on the PCB on one side near the FFC connector there is a small notch in the PCB substrate. This is to allow you access to the two screws. Rotate the PCB assembly so that this notch lines up with each screw and remove them.
    • NOTE: You do not need to fully remove the screws yet. Just make sure they're no longer holding the PCB into the outer ring.
    Ask FixBot
  15. Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Remove screws from encoder assembly: step 16, image 1 of 3 Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Remove screws from encoder assembly: step 16, image 2 of 3 Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Remove screws from encoder assembly: step 16, image 3 of 3
    • Carefully remove the two JIS-000 screws from the encoder assembly. I recommend needle nose pliers to assist with this. Aligning the PCB notch with the screws will help with removing the screws.
    • CAUTION: When rotating the PCB with the screws loose, make sure the screw heads are flush against the plastic encoder assembly and not touching the PCB. If the screw heads are touching the PCB while rotating, they can bind up and risk damaging the PCB.
    Ask FixBot
  16. Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Separate the encoder halves: step 17, image 1 of 2 Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Separate the encoder halves: step 17, image 2 of 2
    • WARNING: This is where the most delicate parts are. Be extremely careful here!
    • If you look in the middle of the assembly, you'll notice there are four little metal tabs holding the top and bottom together. Use the slotted precision screwdriver to gently unclip each tab. You will need to apply a gentle separation force to prevent the tabs from re-engaging when you move on to the next tab.
    • NOTE: The picture here showing three of the metal tabs was taken after the two encoder halves were separated.
    Ask FixBot
  17. Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Reshape the wiper arms: step 18, image 1 of 1
    • On the half that doesn't have the PCB, you should see three wiper arms that make contact with the encoder traces on the other half of the encoder assembly. Using the precision slotted screwdriver, gently bend these outward so they protrude further into the air.
    • Don't over-do it when bending the wiper arms. The amount of bending I'm displaying in the picture is a little on the excessive side. Do not exceed the bending angle I'm showing here.
    Ask FixBot
  18. Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Optional: Clean the encoder traces and re-apply dielectric grease: step 19, image 1 of 1
    • NOTE: I didn't think to do this until after I started writing this guide so I didn't do this on my keyboard. Despite that, my volume knob is usable again. It will still get a little confused about which direction it's rotating once in a while but it's negligible and not causing problems. I can't help but wonder if it would be 100% if I had.
    • Using a Q-Tip and some rubbing alcohol, gently clean out the encoder traces (the area in between the two red circles in the image). The goal is to remove the existing dielectric grease.
    • Once clean, apply new dielectric grease to the encoder traces. Apply about the same amount as what you removed during the cleaning process. Adding a little extra shouldn't be a problem as long as you don't go overboard with it.
    • CAUTION: Be extremely careful not to dislodge the small spring on the outer edge.
    Ask FixBot
  19. Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Re-assemble encoder assembly: step 20, image 1 of 3 Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Re-assemble encoder assembly: step 20, image 2 of 3 Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Re-assemble encoder assembly: step 20, image 3 of 3
    • The non-PCB side of the encoder has a larger metal area on one side, that I didn't take a picture of, that lines up with the square area on the PCB side where the spring is located. Carefully align the two sides of the encoder, ensuring the wiper arms make contact with the encoder traces.
    • Gently press the two sides together so that the four metal tabs engage and hold the assembly together.
    • Ensure the PCB can swivel around normally like it did before disassembly and that all four metal tabs are properly engaged.
    • Insert the two JIS-000 screws into the encoder assembly using the PCB notch for better access.
    • Rotate the PCB so that the notch is aligned with one of the screws.
    • Insert the encoder assembly into the knurled outer ring. Take care to ensure the screws line up with the threaded holes in the underside of the knurled outer ring.
    • Tighten the screw that is currently aligned with the PCB notch.
    • CAUTION: Be extremely careful when rotating the PCB to align the second screw. The screw tends to bind on the PCB and can cause damage.
    Ask FixBot
  20. Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Re-assemble and insert the knob carrier assembly: step 21, image 1 of 3 Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Re-assemble and insert the knob carrier assembly: step 21, image 2 of 3 Razer Huntsman Elite Gaming Keyboard Volume Knob Repair, Re-assemble and insert the knob carrier assembly: step 21, image 3 of 3
    • Insert the mute button into the knob assembly. It can only go in two ways. Ensure the speaker portion of the mute icon is on the same side of the assembly as the FFC connector on the PCB.
    • While ensuring the mute button doesn't fall back out, insert the knob assembly into the knob assembly carrier. It will only fit one way due to the FFC connector.
    • While ensuring the mute button doesn't fall out, insert and tighten the two JIS-000 screws.
    • Carefully align the knob carrier assembly over the four guide pins and gently press the knob carrier into place. Be especially careful with the two smaller guide pins.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order, including the prerequisite guide.
When tightening screws during re-assembly, keep in mind that all the screws are driving into plastic. Be very careful not to torque them down.
HDL_CinC_Dragon
216 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 24
Past 30 Days: 114
All Time: 1,743
