Razer Deathadder Elite Scroll Wheel Replacement
Views: 8.4K
View statistics:
Past 24 Hours:
11
Past 7 Days:
61
Past 30 Days:
220
All Time:
8,375
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your Razer Deathadder Elite has experienced a detached mouse wheel, it can inhibit the functions of the mouse. The following tutorial would be used to help people who encounter this issue and don't want to purchase a replacement mouse.
Make sure you really do have a misaligned scroll wheel by shaking your mouse to listen for any rattling around the mouse wheel. Double check to make sure the middle mouse click buttons are working properly as well.
Don't worry about breaking anything because all parts of the mouse are durable and easily removable.
Before beginning, make sure to unplug your mouse from whatever device it may be attached to.
Tools
    1. Razer Deathadder Elite Scroll Wheel Replacement, Scroll Wheel: step 1, image 1 of 2 Razer Deathadder Elite Scroll Wheel Replacement, Scroll Wheel: step 1, image 2 of 2
      • Pry the skate off the two upper screws.
      • Remove the two upper screws using a Phillips #00 screwdriver.
      • Poke a hole with your screwdriver into the product sticker on the bottom of the mouse.
      • Remove the bottom screw using a Phillips #00 screwdriver.
      Ask FixBot
    2. Razer Deathadder Elite Scroll Wheel Replacement: step 2, image 1 of 2 Razer Deathadder Elite Scroll Wheel Replacement: step 2, image 2 of 2
      • Lift up the upper shell of the mouse.
      • Use caution; the shell if still connected to the base.
      • Detach the two wired connectors from the circuit board.
      Ask FixBot
    3. Razer Deathadder Elite Scroll Wheel Replacement: step 3, image 1 of 3 Razer Deathadder Elite Scroll Wheel Replacement: step 3, image 2 of 3 Razer Deathadder Elite Scroll Wheel Replacement: step 3, image 3 of 3
      • Unscrew the scroll wheel LED.
      • Carefully remove the scroll wheel.
      Ask FixBot
    4. Razer Deathadder Elite Scroll Wheel Replacement: step 4, image 1 of 1
      • Insert the replacement wheel into the mouse.
      Ask FixBot
8 other people completed this guide.
Hamilton Liu
256 Reputation
1 Guide authored
1 Guide Comment
Hi! What size and manufacturer is the encoder in this mouse?
m2l2kopower - Reply Share
Past 24 Hours: 11
Past 7 Days: 61
Past 30 Days: 220
All Time: 8,375
