Razer DeathAdder Chroma Optical Sensor Replacement
Views: 7.6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
126
All Time:
7,558
Comments: 6
3 comments on steps, 3 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 7 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
The optical sensor for the Razer DeathAdder Chroma is a crucial component for the device’s operation. A critical failure of the optical sensor will necessarily require a replacement.
Tools
    1. Razer DeathAdder Chroma Optical Sensor Replacement, Outer Casing: step 1, image 1 of 1
      • Opening the mouse casing will void any warranty that exists for the mouse.
      • Turn the mouse over so the bottom is facing up.
      Ask FixBot
    2. Razer DeathAdder Chroma Optical Sensor Replacement: step 2, image 1 of 2 Razer DeathAdder Chroma Optical Sensor Replacement: step 2, image 2 of 2
      • Use the blunt end of the spudger to pry the adhesive rubber pads from the top left and right edges.
      Ask FixBot
    3. Razer DeathAdder Chroma Optical Sensor Replacement: step 3, image 1 of 2 Razer DeathAdder Chroma Optical Sensor Replacement: step 3, image 2 of 2
      • Use a Phillips #0 screwdriver to remove two 6.7 mm screws.
      Ask FixBot
    4. Razer DeathAdder Chroma Optical Sensor Replacement: step 4, image 1 of 1
      • Use your fingers to identify the location of the screw under the bottom label.
      Ask FixBot
    5. Razer DeathAdder Chroma Optical Sensor Replacement: step 5, image 1 of 1
      • Use a Phillips #0 screwdriver to remove one 6.7 mm screw.
      • Clear the label away from around the screw for easier removal.
      Ask FixBot
    6. Razer DeathAdder Chroma Optical Sensor Replacement: step 6, image 1 of 3 Razer DeathAdder Chroma Optical Sensor Replacement: step 6, image 2 of 3 Razer DeathAdder Chroma Optical Sensor Replacement: step 6, image 3 of 3
      • Turn the mouse over so the bottom is facing down.
      • Separate the top casing from the bottom base by pulling the top casing upwards.
      • Separating the casing too quickly could damage the ribbon connector between the motherboard and the LED lights.
      Ask FixBot
    7. Razer DeathAdder Chroma Optical Sensor Replacement: step 7, image 1 of 2 Razer DeathAdder Chroma Optical Sensor Replacement: step 7, image 2 of 2
      • Disconnect the ribbon connector between the motherboard and the LED lights by pulling upward.
      • Pulling too hard could damage the wire connections.
      Ask FixBot
    1. Razer DeathAdder Chroma Optical Sensor Replacement, Motherboard: step 8, image 1 of 2 Razer DeathAdder Chroma Optical Sensor Replacement, Motherboard: step 8, image 2 of 2
      • Disconnect the ribbon connector between the motherboard and the USB cable by pulling upward.
      Ask FixBot
    2. Razer DeathAdder Chroma Optical Sensor Replacement: step 9, image 1 of 1
      • Use a Phillips #0 screwdriver to remove three 5.5 mm screws.
      Ask FixBot
    3. Razer DeathAdder Chroma Optical Sensor Replacement: step 10, image 1 of 2 Razer DeathAdder Chroma Optical Sensor Replacement: step 10, image 2 of 2
      • Use a Phillips #0 screwdriver to remove two 11.5 mm screws on the side buttons.
      Ask FixBot
    4. Razer DeathAdder Chroma Optical Sensor Replacement: step 11, image 1 of 1
      • Use a Phillips #000 screwdriver to remove one 5.0 mm screw.
      Ask FixBot
    5. Razer DeathAdder Chroma Optical Sensor Replacement: step 12, image 1 of 2 Razer DeathAdder Chroma Optical Sensor Replacement: step 12, image 2 of 2
      • Disconnect the ribbon connector between the motherboard and the optical sensor.
      Ask FixBot
    6. Razer DeathAdder Chroma Optical Sensor Replacement: step 13, image 1 of 2 Razer DeathAdder Chroma Optical Sensor Replacement: step 13, image 2 of 2
      • Remove the motherboard by grasping the sides and gently pulling upward.
      Ask FixBot
    1. Razer DeathAdder Chroma Optical Sensor Replacement, Optical Sensor: step 14, image 1 of 2 Razer DeathAdder Chroma Optical Sensor Replacement, Optical Sensor: step 14, image 2 of 2
      • Use a Phillips #0 screwdriver to remove two 5.5mm screws.
      Ask FixBot
    2. Razer DeathAdder Chroma Optical Sensor Replacement: step 15, image 1 of 2 Razer DeathAdder Chroma Optical Sensor Replacement: step 15, image 2 of 2
      • Remove the optical sensor by pulling it forward and up.
      Ask FixBot
5 other people completed this guide.
Nathan D. Kappler
343 Reputation
2 Guides authored
Baylor, Team S5-G2, Williams Spring 2017 Member of Baylor, Team S5-G2, Williams Spring 2017
BU-WILLIAMS-S17S5G2
3 Members
60 Guides authored
3 Guide Comments
Where do I get the part?
youarestaringatme - Reply Share
This is not a sensor, but a sensor backlight. Sensor on the underside of the main board
Guest Night - Reply Share
Didn't say what to do clean it or replace it again only remove the parts
Timothy John Bautista - Reply Share
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 126
All Time: 7,558
