Razer Cynosa Lite Keyboard Membrane Replacement
  1. Razer Cynosa Lite Keyboard Membrane Replacement, Membrane: step 1, image 1 of 3 Razer Cynosa Lite Keyboard Membrane Replacement, Membrane: step 1, image 2 of 3 Razer Cynosa Lite Keyboard Membrane Replacement, Membrane: step 1, image 3 of 3
    • Make sure keyboard is unplugged from your computer before starting.
    • Use a keycap puller and remove each key from the device.
    • If you don't have a keycaps puller, use a thin object like a spudger or opening pick and insert it underneath the key. In an upward motion pop the key out. Use your other hand to prevent keys from flying off the work space.
    Ask FixBot
  2. Razer Cynosa Lite Keyboard Membrane Replacement: step 2, image 1 of 3 Razer Cynosa Lite Keyboard Membrane Replacement: step 2, image 2 of 3 Razer Cynosa Lite Keyboard Membrane Replacement: step 2, image 3 of 3
    • Flip keyboard upside down.
    • Remove the four corner stickers to reveal screws.
    • Remove all four 2 mm screws under the stickers with a Phillips #1 screwdriver.
    • Place the screws in safe space so you can easily access them when reassembling.
    Ask FixBot
  3. Razer Cynosa Lite Keyboard Membrane Replacement: step 3, image 1 of 2 Razer Cynosa Lite Keyboard Membrane Replacement: step 3, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the remaining twelve screws from the bottom of the keyboard.
    Ask FixBot
  4. Razer Cynosa Lite Keyboard Membrane Replacement: step 4, image 1 of 2 Razer Cynosa Lite Keyboard Membrane Replacement: step 4, image 2 of 2
    • At the very bottom of your computer, create an opening between the top and bottom covers of the keyboard using your fingers.
    • Insert a spudger into the space and slide it around the perimeter to release the clips that connect the top and bottom case.
    • Move the spudger slowly to ensure the internal components and clips avoid damage.
    • Flip the keyboard so the top side is facing up, then carefully separate the top cover from the bottom casing.
    Ask FixBot
  5. Razer Cynosa Lite Keyboard Membrane Replacement: step 5, image 1 of 3 Razer Cynosa Lite Keyboard Membrane Replacement: step 5, image 2 of 3 Razer Cynosa Lite Keyboard Membrane Replacement: step 5, image 3 of 3
    • Use a Phillips #1 screwdriver to remove three 2 mm screws from the bracket at the right corner of the keyboard.
    • Remove the bracket from the keyboard.
    Ask FixBot
  6. Razer Cynosa Lite Keyboard Membrane Replacement: step 6, image 1 of 2 Razer Cynosa Lite Keyboard Membrane Replacement: step 6, image 2 of 2
    • Use tweezers to grab the edge of the membrane and remove the membrane layers from the keyboard.
    • Carefully remove the membrane, taking your time to avoid damaging any other components of the keyboard.
    Ask FixBot
  7. Razer Cynosa Lite Keyboard Membrane Replacement: step 7, image 1 of 3 Razer Cynosa Lite Keyboard Membrane Replacement: step 7, image 2 of 3 Razer Cynosa Lite Keyboard Membrane Replacement: step 7, image 3 of 3
    • Use a Phillips #1 screwdriver to remove the eight 2 mm screws from the keyboard overlay and shield and separate them.
    • Clean the inside of the keyboard with a cloth or alcohol wipes if needed.
    Ask FixBot
  8. Razer Cynosa Lite Keyboard Membrane Replacement: step 8, image 1 of 3 Razer Cynosa Lite Keyboard Membrane Replacement: step 8, image 2 of 3 Razer Cynosa Lite Keyboard Membrane Replacement: step 8, image 3 of 3
    • Using tweezers, align the new membrane's screw hole near the top right.
    • Align all of the divots in the membrane with the screw holes.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Roen Wang
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 21
Past 30 Days: 71
All Time: 930
