Razer Carcharias Volume Potentiometer Replacement
  1. Razer Carcharias Volume Potentiometer Replacement, Opening the case: step 1, image 1 of 2 Razer Carcharias Volume Potentiometer Replacement, Opening the case: step 1, image 2 of 2
    • Use a pry tool to pry apart the volume adjuster case.
    • There are 4 clips on each side that may be broken - if that happens then expect to glue the case back together.
    • Remove the 2 screws holding the PCB onto the case.
    Ask FixBot
  2. Razer Carcharias Volume Potentiometer Replacement, Removing the faulty potentiometer: step 2, image 1 of 2 Razer Carcharias Volume Potentiometer Replacement, Removing the faulty potentiometer: step 2, image 2 of 2
    • Using a thin tool, pry up the 2 legs locking the potentiometer to the board.
    • Optionally remove as much original solder using the soldering iron and braided solder wick. While gently prying the potentiometer upwards, use the soldering iron to heat the 5 pads of the potentiometer until the component is freed.
    Ask FixBot
  3. Razer Carcharias Volume Potentiometer Replacement, Connecting the new potentiometer: step 3, image 1 of 3 Razer Carcharias Volume Potentiometer Replacement, Connecting the new potentiometer: step 3, image 2 of 3 Razer Carcharias Volume Potentiometer Replacement, Connecting the new potentiometer: step 3, image 3 of 3
    • Use a pair of pliers or strong tweezers to bend the leads on the new potentiometer straight.
    • Place the new potentiometer onto the board, making sure to pass the locking tabs through the board.
    • Solder the 5 leads while applying pressure to the top of the potentiometer so that it moves flush with the board while the solder is still liquid.
    • Since the locking tabs extend through the PCB, it's helpful to place the PCB on the edge of something like a cardboard box while soldering so that the locking tabs are free to extend below the PCB, allowing the potentiometer to be completely flush with the PCB.
    • Bend the 2 retaining tabs on the other side of the board flush using a spudger tool.
    • Now is a good time to test that the volume knob and microphone still work before reassembling the case.
    • If flux was used during the soldering process, it's a good idea to clean it off using isopropyl alcohol or a circuit-friendly cleaning solution before reassembly.
    Ask FixBot
  4. Razer Carcharias Volume Potentiometer Replacement, Reassembly: step 4, image 1 of 2 Razer Carcharias Volume Potentiometer Replacement, Reassembly: step 4, image 2 of 2
    • If the "Mic" switch was removed, be sure to reattach it before putting the PCB back into the case.
    • Replace the 2 screws used to secure the PCB into the case.
    • Slot both rubber pieces back into the ends of the housing.
    • If the plastic clips were broken, apply glue to the marked areas to hold the case closed. Cyanoacrylate glue (superglue) or B7000 glue will work.
    • Press the case firmly closed and wait for the glue to dry.
    Ask FixBot
Finish Line
Stephen Smith
305 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 38
All Time: 455
