Razer Blade Stealth 2017 Display Assembly Replacement
    1. Razer Blade Stealth 2017 Display Assembly Replacement, Battery: step 1, image 1 of 2 Razer Blade Stealth 2017 Display Assembly Replacement, Battery: step 1, image 2 of 2
      • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
      • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
      • Whenever you remove screws from the device, remember to save and label them.
      Ask FixBot
    2. Razer Blade Stealth 2017 Display Assembly Replacement: step 2, image 1 of 1
      • Remove the bottom cover of the laptop by sliding it away from the hinge.
      • Do not force the cover up!
      Ask FixBot
    3. Razer Blade Stealth 2017 Display Assembly Replacement: step 3, image 1 of 2 Razer Blade Stealth 2017 Display Assembly Replacement: step 3, image 2 of 2
      • Use your fingernail to pry up and disconnect the battery from the motherboard.
      Ask FixBot
    4. Razer Blade Stealth 2017 Display Assembly Replacement: step 4, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
      Ask FixBot
    5. Razer Blade Stealth 2017 Display Assembly Replacement: step 5, image 1 of 2 Razer Blade Stealth 2017 Display Assembly Replacement: step 5, image 2 of 2
      • Remove any tape attached to the battery.
      • Use the plastic spudger to pry out the battery.
      Ask FixBot
    1. Razer Blade Stealth 2017 Display Assembly Replacement, Display Assembly: step 6, image 1 of 2 Razer Blade Stealth 2017 Display Assembly Replacement, Display Assembly: step 6, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the six 4 mm screws securing the display assembly.
      Ask FixBot
    2. Razer Blade Stealth 2017 Display Assembly Replacement: step 7, image 1 of 3 Razer Blade Stealth 2017 Display Assembly Replacement: step 7, image 2 of 3 Razer Blade Stealth 2017 Display Assembly Replacement: step 7, image 3 of 3
      • Use the plastic spudger to remove the plastic brackets beneath the hinges.
      Ask FixBot
    3. Razer Blade Stealth 2017 Display Assembly Replacement: step 8, image 1 of 2 Razer Blade Stealth 2017 Display Assembly Replacement: step 8, image 2 of 2
      • Remove any tape attached to the wires.
      • Use the plastic spudger to slide the connectors to the right to disconnect them.
      Ask FixBot
    4. Razer Blade Stealth 2017 Display Assembly Replacement: step 9, image 1 of 2 Razer Blade Stealth 2017 Display Assembly Replacement: step 9, image 2 of 2
      • Use the plastic spudger to lift the connector off of the socket.
      Ask FixBot
    5. Razer Blade Stealth 2017 Display Assembly Replacement: step 10, image 1 of 2 Razer Blade Stealth 2017 Display Assembly Replacement: step 10, image 2 of 2
      • Use your fingers to lift connectors off of their sockets.
      Ask FixBot
    6. Razer Blade Stealth 2017 Display Assembly Replacement: step 11, image 1 of 2 Razer Blade Stealth 2017 Display Assembly Replacement: step 11, image 2 of 2
      • Lift the screen to the open position.
      • Remove the display assembly by sliding it away from the keyboard.
      • Do not force the display assembly off!
      Ask FixBot
Kris Ritter
173 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 85
All Time: 829
