Up to 20% off select tools
Razer Blade Stealth 2016 RAM Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
77
All Time:
2,092
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
The RAM or random access memory in your Razer Blade Stealth 2016 (Model # RZ09-01682E20) is a type of memory that stores working data and possibly machine code, in a short term memory. If your RAM fails then this can significantly slow down your computer. This guide will show you how to remove and replace the RAM in your Razor Blade Stealth 2016.
WARNING: The soldering iron gets very hot, so be cautious while using it.
    1. Razer Blade Stealth 2016 RAM Replacement, Battery: step 1, image 1 of 3 Razer Blade Stealth 2016 RAM Replacement, Battery: step 1, image 2 of 3 Razer Blade Stealth 2016 RAM Replacement, Battery: step 1, image 3 of 3
      • Use a Torx (T5) screwdriver to remove the eight 3 mm screws on the back case.
      • Remove the rear cover by prying up lightly starting in one of the corners.
      Ask FixBot
    2. Razer Blade Stealth 2016 RAM Replacement: step 2, image 1 of 2 Razer Blade Stealth 2016 RAM Replacement: step 2, image 2 of 2
      • Use a Phillips screwdriver to remove the six screws securing the battery.
      Ask FixBot
    3. Razer Blade Stealth 2016 RAM Replacement: step 3, image 1 of 1
      • Unplug the battery connector from the motherboard.
      • Remove the battery from the device.
      Ask FixBot
    1. Razer Blade Stealth 2016 RAM Replacement, RAM: step 4, image 1 of 1
      • Remove the red and black cables that are attached to the motherboard.
      Ask FixBot
    2. Razer Blade Stealth 2016 RAM Replacement: step 5, image 1 of 1
      • Remove the four 3.4 mm screws around the black square using a T4 Torx screwdriver.
      • Remove the heat sink.
      Ask FixBot
    3. Razer Blade Stealth 2016 RAM Replacement: step 6, image 1 of 1
      • Remove the 3.4 mm screws to the cooling fans using a T4 Torx screwdriver.
      • Remove the cooling fans.
      Ask FixBot
    4. Razer Blade Stealth 2016 RAM Replacement: step 7, image 1 of 2 Razer Blade Stealth 2016 RAM Replacement: step 7, image 2 of 2
      • Remove the 3.4 mm screws on the perimeter of the motherboard using a T4 Torx screwdriver.
      Ask FixBot
    5. Razer Blade Stealth 2016 RAM Replacement: step 8, image 1 of 1
      • Remove the motherboard.
      Ask FixBot
    6. Razer Blade Stealth 2016 RAM Replacement: step 9, image 1 of 1
      • Desolder the pins on the motherboard to remove the RAM.
      • WARNING: Be careful while using the soldering iron.
      Ask FixBot
Author
with
SadieGomez
352 Reputation
3 Guides authored
2 Guide Comments
fanboy bowing down
Hal - Reply Share
Does anyone know what RAM modules I could use to replace the 8gb my 2016 stealth has? It still runs flawlessly but I'd like to have at least 16gb if possible.
Mike D - Reply Share
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 77
All Time: 2,092
