Razer Blade Stealth 2016 Motherboard Replacement
    1. Razer Blade Stealth 2016 Motherboard Replacement, Battery: step 1, image 1 of 3 Razer Blade Stealth 2016 Motherboard Replacement, Battery: step 1, image 2 of 3 Razer Blade Stealth 2016 Motherboard Replacement, Battery: step 1, image 3 of 3
      • Use a Torx (T5) screwdriver to remove the eight 3 mm screws on the back case.
      • Remove the rear cover by prying up lightly starting in one of the corners.
      Ask FixBot
    2. Razer Blade Stealth 2016 Motherboard Replacement: step 2, image 1 of 2 Razer Blade Stealth 2016 Motherboard Replacement: step 2, image 2 of 2
      • Use a Phillips screwdriver to remove the six screws securing the battery.
      Ask FixBot
    3. Razer Blade Stealth 2016 Motherboard Replacement: step 3, image 1 of 1
      • Unplug the battery connector from the motherboard.
      • Remove the battery from the device.
      Ask FixBot
    1. Razer Blade Stealth 2016 Motherboard Replacement, Motherboard: step 4, image 1 of 1
      • Remove the red and black cables that are attached to the motherboard.
      Ask FixBot
    2. Razer Blade Stealth 2016 Motherboard Replacement: step 5, image 1 of 1
      • Remove the four 3.4 mm screws around the black square using a T4 Torx screwdriver.
      • Remove the heatsink.
      Ask FixBot
    3. Razer Blade Stealth 2016 Motherboard Replacement: step 6, image 1 of 1
      • Remove the 3.4 mm screws to the cooling fans using a T4 Torx screwdriver.
      • Remove the cooling fans.
      Ask FixBot
    4. Razer Blade Stealth 2016 Motherboard Replacement: step 7, image 1 of 3 Razer Blade Stealth 2016 Motherboard Replacement: step 7, image 2 of 3 Razer Blade Stealth 2016 Motherboard Replacement: step 7, image 3 of 3
      • Remove the 3.4 mm screws on the perimeter of the motherboard using a T4 Torx screwdriver.
      Ask FixBot
    5. Razer Blade Stealth 2016 Motherboard Replacement: step 8, image 1 of 1
      • Remove the motherboard.
      Ask FixBot
2 Guide Comments
Hi Sadie. It's complicated for me with the battery disconnector, I can't remove it. would you help me with that?
Matias Urani - Reply Share
Hi @matiasurani. It looks like the connector is covered by tape so you might have to remove the tape first. The battery is connected to the motherboard by a press connector. Take a look at this guide for how to disconnect it safely. Thanks!
Sarah Westberg - Reply Share
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 57
All Time: 1,458
