Razer Blade Stealth 2016 Keyboard Replacement
    1. Razer Blade Stealth 2016 Keyboard Replacement, Battery: step 1, image 1 of 3 Razer Blade Stealth 2016 Keyboard Replacement, Battery: step 1, image 2 of 3 Razer Blade Stealth 2016 Keyboard Replacement, Battery: step 1, image 3 of 3
      • Use a Torx (T5) screwdriver to remove the eight 3 mm screws on the back case.
      • Remove the rear cover by prying up lightly starting in one of the corners.
      Ask FixBot
    2. Razer Blade Stealth 2016 Keyboard Replacement: step 2, image 1 of 2 Razer Blade Stealth 2016 Keyboard Replacement: step 2, image 2 of 2
      • Use a Phillips screwdriver to remove the six screws securing the battery.
      Ask FixBot
    3. Razer Blade Stealth 2016 Keyboard Replacement: step 3, image 1 of 1
      • Unplug the battery connector from the motherboard.
      • Remove the battery from the device.
      Ask FixBot
    1. Razer Blade Stealth 2016 Keyboard Replacement, Motherboard: step 4, image 1 of 1
      • Remove the red and black cables that are attached to the motherboard.
      Ask FixBot
    2. Razer Blade Stealth 2016 Keyboard Replacement: step 5, image 1 of 1
      • Remove the four 3.4 mm screws around the black square using a T4 Torx screwdriver.
      • Remove the heatsink.
      Ask FixBot
    3. Razer Blade Stealth 2016 Keyboard Replacement: step 6, image 1 of 1
      • Remove the 3.4 mm screws to the cooling fans using a T4 Torx screwdriver.
      • Remove the cooling fans.
      Ask FixBot
    4. Razer Blade Stealth 2016 Keyboard Replacement: step 7, image 1 of 3 Razer Blade Stealth 2016 Keyboard Replacement: step 7, image 2 of 3 Razer Blade Stealth 2016 Keyboard Replacement: step 7, image 3 of 3
      • Remove the 3.4 mm screws on the perimeter of the motherboard using a T4 Torx screwdriver.
      Ask FixBot
    5. Razer Blade Stealth 2016 Keyboard Replacement: step 8, image 1 of 1
      • Remove the motherboard.
      Ask FixBot
    1. Razer Blade Stealth 2016 Keyboard Replacement, Keyboard: step 9, image 1 of 3 Razer Blade Stealth 2016 Keyboard Replacement, Keyboard: step 9, image 2 of 3 Razer Blade Stealth 2016 Keyboard Replacement, Keyboard: step 9, image 3 of 3
      • Flip all white tabs up to unlock three ZIF connectors using the opening tool.
      • Flip all black tabs up to unlock the three ZIF connectors using the opening tool.
      • This is how the tabs look in the flipped up position.
      Ask FixBot
    2. Razer Blade Stealth 2016 Keyboard Replacement: step 10, image 1 of 3 Razer Blade Stealth 2016 Keyboard Replacement: step 10, image 2 of 3 Razer Blade Stealth 2016 Keyboard Replacement: step 10, image 3 of 3
      • Pull the cables out gently.
      Ask FixBot
    3. Razer Blade Stealth 2016 Keyboard Replacement: step 11, image 1 of 3 Razer Blade Stealth 2016 Keyboard Replacement: step 11, image 2 of 3 Razer Blade Stealth 2016 Keyboard Replacement: step 11, image 3 of 3
      • Remove fifty-five 3.4 mm keyboard screws with the T5 Torx screwdriver.
      • 5 screw locations are highlighted but locate all 55 screws and remove them.
      Ask FixBot
    4. Razer Blade Stealth 2016 Keyboard Replacement: step 12, image 1 of 3 Razer Blade Stealth 2016 Keyboard Replacement: step 12, image 2 of 3 Razer Blade Stealth 2016 Keyboard Replacement: step 12, image 3 of 3
      • Remove the keyboard from the laptop.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 73
All Time: 1,607
