Up to 20% off select tools
Razer Blade Stealth 2016 Fan Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
74
All Time:
2,679
Comments: 7
5 comments on steps, 2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 9 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The purpose of computer fans is to cool down the device. As the computer is operating, the device produces heat. The fans will bring cooler air in to cool down the device. The fans are meant to cool the device down, if this part fails to do this, the computer could shutdown and need a reboot. If your fans in your Razer Blade Stealth 2016 isn't working properly, this guide will show you how to remove and replace the fans.
    1. Razer Blade Stealth 2016  Fan Replacement, Battery: step 1, image 1 of 3 Razer Blade Stealth 2016  Fan Replacement, Battery: step 1, image 2 of 3 Razer Blade Stealth 2016  Fan Replacement, Battery: step 1, image 3 of 3
      • Use a Torx (T5) screwdriver to remove the eight 3 mm screws on the back case.
      • Remove the rear cover by prying up lightly starting in one of the corners.
      Ask FixBot
    2. Razer Blade Stealth 2016  Fan Replacement: step 2, image 1 of 2 Razer Blade Stealth 2016  Fan Replacement: step 2, image 2 of 2
      • Use a Phillips screwdriver to remove the six screws securing the battery.
      Ask FixBot
    3. Razer Blade Stealth 2016  Fan Replacement: step 3, image 1 of 1
      • Unplug the battery connector from the motherboard.
      • Remove the battery from the device.
      Ask FixBot
    1. Razer Blade Stealth 2016  Fan Replacement, Fans: step 4, image 1 of 2 Razer Blade Stealth 2016  Fan Replacement, Fans: step 4, image 2 of 2
      • Remove the three 3.38 mm screws from the left fan (this fan should be black).
      Ask FixBot
    2. Razer Blade Stealth 2016  Fan Replacement: step 5, image 1 of 1
      • Carefully lift and remove the left fan.
      Ask FixBot
    3. Razer Blade Stealth 2016  Fan Replacement: step 6, image 1 of 3 Razer Blade Stealth 2016  Fan Replacement: step 6, image 2 of 3 Razer Blade Stealth 2016  Fan Replacement: step 6, image 3 of 3
      • Repeat steps five and six to remove the silver, right fan.
      Ask FixBot
Author
with
Katie Murphy
142 Reputation
1 Guide authored
USF Tampa, Team S1-G4, Leahy Fall 2019 Member of USF Tampa, Team S1-G4, Leahy Fall 2019
USFT-LEAHY-F19S1G4
4 Members
60 Guides authored
2 Guide Comments
I’m trying to figure out how to attach the ribbons to the motherboard.
Richard Howard - Reply Share
Are the two fans the same?
Mohd Azli Mahmud - Reply Share
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 74
All Time: 2,679
