Razer Blade RZ09-0130 2015 Display Replacement
    1. Razer Blade RZ09-0130 2015 Display Replacement, Back Panel: step 1, image 1 of 2 Razer Blade RZ09-0130 2015 Display Replacement, Back Panel: step 1, image 2 of 2
      • Be sure to power off the device before beginning.
      • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
      Ask FixBot
    2. Razer Blade RZ09-0130 2015 Display Replacement: step 2, image 1 of 2 Razer Blade RZ09-0130 2015 Display Replacement: step 2, image 2 of 2
      • Remove the back panel from the laptop by sliding it away from the hinge.
      • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
      Ask FixBot
    1. Razer Blade RZ09-0130 2015 Display Replacement, Display: step 3, image 1 of 1
      • Remove the two 5mm Phillips #00 screws.
      Ask FixBot
    2. Razer Blade RZ09-0130 2015 Display Replacement: step 4, image 1 of 1
      • Remove the plastic panel.
      Ask FixBot
    3. Razer Blade RZ09-0130 2015 Display Replacement: step 5, image 1 of 1
      • Remove one 3mm Phillips #00 screw from the metal plate.
      Ask FixBot
    4. Razer Blade RZ09-0130 2015 Display Replacement: step 6, image 1 of 1
      • Repeat the previous three steps on the opposing side.
      Ask FixBot
    5. Razer Blade RZ09-0130 2015 Display Replacement: step 7, image 1 of 1
      • Gently open the device with your hands and separate the display from the keyboard.
      • The device will make a popping or cracking sound when the two pieces separate. This is normal.
      Ask FixBot
Ben Haering
139 Reputation
1 Guide authored
Cal Poly, Team S18-G1, White Winter 2020 Member of Cal Poly, Team S18-G1, White Winter 2020
CPSU-WHITE-W20S18G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 26
All Time: 1,229
