Razer Blade 2014 Battery Replacement
    1. Razer Blade 2014 Battery Replacement, Battery: step 1, image 1 of 2 Razer Blade 2014 Battery Replacement, Battery: step 1, image 2 of 2
      • Use a P2 Pentalobe screwdriver to remove the ten screws on the laptop's backplate.
      Ask FixBot
    2. Razer Blade 2014 Battery Replacement: step 2, image 1 of 2 Razer Blade 2014 Battery Replacement: step 2, image 2 of 2
      • Squeeze the sides of the backplate with your hands and lift up the backplate.
      Ask FixBot
    3. Razer Blade 2014 Battery Replacement: step 3, image 1 of 2 Razer Blade 2014 Battery Replacement: step 3, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the five screws from the battery.
      Ask FixBot
    4. Razer Blade 2014 Battery Replacement: step 4, image 1 of 2 Razer Blade 2014 Battery Replacement: step 4, image 2 of 2
      • Use tweezers to detach the silver connector that is attached to the battery with an orange cable.
      Ask FixBot
    5. Razer Blade 2014 Battery Replacement: step 5, image 1 of 3 Razer Blade 2014 Battery Replacement: step 5, image 2 of 3 Razer Blade 2014 Battery Replacement: step 5, image 3 of 3
      • Make sure the black cable retaining flap has been completely lifted upwards before pulling the blue cable outwards.
      • Use tweezers to gently lift the retaining flap upwards.
      • Use tweezers to gently pull the white cable outward.
      • Take out the old battery and place the new one in the position of the 5 screw holes.
      Ask FixBot
Ray Luo
199 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 106
All Time: 1,178
