Razer Blade 15" (2020) SSD Replacement
    1. Razer Blade 15" (2020) SSD Replacement, Prepare your laptop for disassembly: step 1, image 1 of 2 Razer Blade 15" (2020) SSD Replacement, Prepare your laptop for disassembly: step 1, image 2 of 2
      • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
      • Unplug all cables and fully shut down your laptop.
      • Close the lid and flip your laptop over so the back cover faces up.
      Ask FixBot
    1. Razer Blade 15" (2020) SSD Replacement, Unfasten the back cover: step 2, image 1 of 1
      • Use a T5 Torx driver to remove the ten 3.7 mm-long screws securing the back cover.
      Ask FixBot
    2. Razer Blade 15" (2020) SSD Replacement, Loosen the back cover: step 3, image 1 of 3 Razer Blade 15" (2020) SSD Replacement, Loosen the back cover: step 3, image 2 of 3 Razer Blade 15" (2020) SSD Replacement, Loosen the back cover: step 3, image 3 of 3
      • The back cover is lightly secured to the motherboard by thermal pads. Depending on the age of your laptop, it may be easier or harder to remove.
      • Use a finger to pry up the right side of the back cover, starting at the Ethernet port cutout.
      Ask FixBot
    3. Razer Blade 15" (2020) SSD Replacement, Remove the back cover: step 4, image 1 of 3 Razer Blade 15" (2020) SSD Replacement, Remove the back cover: step 4, image 2 of 3 Razer Blade 15" (2020) SSD Replacement, Remove the back cover: step 4, image 3 of 3
      • Remove the back cover slowly, as to avoid tearing the thermal pads underneath.
      • Lay the back cover down on its rubber feet to avoid damaging the thermal pads on its underside.
      Ask FixBot
    1. Razer Blade 15" (2020) SSD Replacement, Soften the battery cable tape adhesive: step 5, image 1 of 2 Razer Blade 15" (2020) SSD Replacement, Soften the battery cable tape adhesive: step 5, image 2 of 2
      • Apply a heated iOpener to the battery cable tape for one minute.
      • You can also use a hair dryer—but be careful, as overheating the battery may damage it or cause a fire.
      Ask FixBot
    2. Razer Blade 15" (2020) SSD Replacement, Remove the battery cable tape: step 6, image 1 of 3 Razer Blade 15" (2020) SSD Replacement, Remove the battery cable tape: step 6, image 2 of 3 Razer Blade 15" (2020) SSD Replacement, Remove the battery cable tape: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Be careful not to damage the battery with your tool.
      • Use blunt nose tweezers or your fingers to peel and remove the battery cable tape.
      Ask FixBot
    3. Razer Blade 15" (2020) SSD Replacement, Disconnect the battery: step 7, image 1 of 2 Razer Blade 15" (2020) SSD Replacement, Disconnect the battery: step 7, image 2 of 2
      • Use the flat end of a spudger to push the square tab on the battery connector and slide it out of its socket.
      Ask FixBot
    1. Razer Blade 15" (2020) SSD Replacement, Unfasten the SSD: step 8, image 1 of 3 Razer Blade 15" (2020) SSD Replacement, Unfasten the SSD: step 8, image 2 of 3 Razer Blade 15" (2020) SSD Replacement, Unfasten the SSD: step 8, image 3 of 3
      • Use a Phillips screwdriver to remove the 3.1 mm screw securing the SSD.
      • The SSD will pop up slightly.
      Ask FixBot
    2. Razer Blade 15" (2020) SSD Replacement, Remove the SSD: step 9, image 1 of 3 Razer Blade 15" (2020) SSD Replacement, Remove the SSD: step 9, image 2 of 3 Razer Blade 15" (2020) SSD Replacement, Remove the SSD: step 9, image 3 of 3
      • Pull the SSD straight out of its socket and remove it.
      • During reassembly, insert the SSD at a slight downward angle before lowering it flat to the frame and securing it with its screw.
      Ask FixBot
Clay Eickemeyer
107,986 Reputation
472 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
61,972 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 107
All Time: 1,347
