Razer Blade 15" (2020) Left Fan Replacement
    1. Razer Blade 15" (2020) Left Fan Replacement, Prepare your laptop for disassembly: step 1, image 1 of 2 Razer Blade 15" (2020) Left Fan Replacement, Prepare your laptop for disassembly: step 1, image 2 of 2
      • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
      • Unplug all cables and fully shut down your laptop.
      • Close the lid and flip your laptop over so the back cover faces up.
      Ask FixBot
    1. Razer Blade 15" (2020) Left Fan Replacement, Unfasten the back cover: step 2, image 1 of 1
      • Use a T5 Torx driver to remove the ten 3.7 mm-long screws securing the back cover.
      Ask FixBot
    2. Razer Blade 15" (2020) Left Fan Replacement, Loosen the back cover: step 3, image 1 of 3 Razer Blade 15" (2020) Left Fan Replacement, Loosen the back cover: step 3, image 2 of 3 Razer Blade 15" (2020) Left Fan Replacement, Loosen the back cover: step 3, image 3 of 3
      • The back cover is lightly secured to the motherboard by thermal pads. Depending on the age of your laptop, it may be easier or harder to remove.
      • Use a finger to pry up the right side of the back cover, starting at the Ethernet port cutout.
      Ask FixBot
    3. Razer Blade 15" (2020) Left Fan Replacement, Remove the back cover: step 4, image 1 of 3 Razer Blade 15" (2020) Left Fan Replacement, Remove the back cover: step 4, image 2 of 3 Razer Blade 15" (2020) Left Fan Replacement, Remove the back cover: step 4, image 3 of 3
      • Remove the back cover slowly, as to avoid tearing the thermal pads underneath.
      • Lay the back cover down on its rubber feet to avoid damaging the thermal pads on its underside.
      Ask FixBot
    1. Razer Blade 15" (2020) Left Fan Replacement, Soften the battery cable tape adhesive: step 5, image 1 of 2 Razer Blade 15" (2020) Left Fan Replacement, Soften the battery cable tape adhesive: step 5, image 2 of 2
      • Apply a heated iOpener to the battery cable tape for one minute.
      • You can also use a hair dryer—but be careful, as overheating the battery may damage it or cause a fire.
      Ask FixBot
    2. Razer Blade 15" (2020) Left Fan Replacement, Remove the battery cable tape: step 6, image 1 of 3 Razer Blade 15" (2020) Left Fan Replacement, Remove the battery cable tape: step 6, image 2 of 3 Razer Blade 15" (2020) Left Fan Replacement, Remove the battery cable tape: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Be careful not to damage the battery with your tool.
      • Use blunt nose tweezers or your fingers to peel and remove the battery cable tape.
      Ask FixBot
    3. Razer Blade 15" (2020) Left Fan Replacement, Disconnect the battery: step 7, image 1 of 2 Razer Blade 15" (2020) Left Fan Replacement, Disconnect the battery: step 7, image 2 of 2
      • Use the flat end of a spudger to push the square tab on the battery connector and slide it out of its socket.
      Ask FixBot
    1. Razer Blade 15" (2020) Left Fan Replacement, Label the antenna cables: step 8, image 1 of 2 Razer Blade 15" (2020) Left Fan Replacement, Label the antenna cables: step 8, image 2 of 2
      • In the next two steps, you'll disconnect the Wi-Fi antenna cables to access other components.
      • The antenna cables look very similar. Label one of them with a piece of tape or marker and remember which socket it connects to.
      Ask FixBot
    2. Razer Blade 15" (2020) Left Fan Replacement, Disconnect the antenna cables: step 9, image 1 of 3 Razer Blade 15" (2020) Left Fan Replacement, Disconnect the antenna cables: step 9, image 2 of 3 Razer Blade 15" (2020) Left Fan Replacement, Disconnect the antenna cables: step 9, image 3 of 3
      $3.99
      Buy
      • Insert one arm of angled tweezers under the metal neck of each antenna cable and pry up to disconnect it.
      • During reassembly, align the connector over its socket and gently press down with the flat end of your spudger or your fingernail until it clicks into place.
      Ask FixBot
    3. Razer Blade 15" (2020) Left Fan Replacement, Disconnect the screen press connector: step 10, image 1 of 2 Razer Blade 15" (2020) Left Fan Replacement, Disconnect the screen press connector: step 10, image 2 of 2
      • Grab the pull tab on the screen connector.
      • Pull up to disconnect the connector from its socket.
      • During reassembly, align the connector over its socket and press down until it clicks into place.
      Ask FixBot
    4. Razer Blade 15" (2020) Left Fan Replacement, Disconnect the charging port: step 11, image 1 of 3 Razer Blade 15" (2020) Left Fan Replacement, Disconnect the charging port: step 11, image 2 of 3 Razer Blade 15" (2020) Left Fan Replacement, Disconnect the charging port: step 11, image 3 of 3
      • Use the point of your spudger to press on alternating sides of the charging port connector to "walk" it out of its socket.
      Ask FixBot
    5. Razer Blade 15" (2020) Left Fan Replacement, Move the charging cable: step 12, image 1 of 2 Razer Blade 15" (2020) Left Fan Replacement, Move the charging cable: step 12, image 2 of 2
      • Move the charging cable over the right edge of the laptop.
      Ask FixBot
    1. Razer Blade 15" (2020) Left Fan Replacement, Move the screen and antenna cables: step 13, image 1 of 3 Razer Blade 15" (2020) Left Fan Replacement, Move the screen and antenna cables: step 13, image 2 of 3 Razer Blade 15" (2020) Left Fan Replacement, Move the screen and antenna cables: step 13, image 3 of 3
      • Unclip the screen and antenna cables from the fan and move them over the right edge of the laptop.
      Ask FixBot
    1. Razer Blade 15" (2020) Left Fan Replacement, Disconnect the left fan: step 14, image 1 of 2 Razer Blade 15" (2020) Left Fan Replacement, Disconnect the left fan: step 14, image 2 of 2
      Buy
      • Use tweezers or your fingers to grab the rubber sleeve around the left fan cable and pull the connector straight out of its socket.
      Ask FixBot
    2. Razer Blade 15" (2020) Left Fan Replacement, Unfasten the left fan: step 15, image 1 of 1
      • Use a Phillips screwdriver to remove the two 6.7 mm screws securing the left fan.
      Ask FixBot
    3. Razer Blade 15" (2020) Left Fan Replacement, Remove the left fan: step 16, image 1 of 2 Razer Blade 15" (2020) Left Fan Replacement, Remove the left fan: step 16, image 2 of 2
      • Remove the left fan.
      Ask FixBot
Clay Eickemeyer
107,986 Reputation
472 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
61,972 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 79
All Time: 1,113
