Razer Blade 15" (2020) Back Cover Replacement
    1. Razer Blade 15" (2020) Back Cover Replacement, Unfasten the back cover: step 1, image 1 of 1
      • Use a T5 Torx driver to remove the ten 3.7 mm-long screws securing the back cover.
      Ask FixBot
    2. Razer Blade 15" (2020) Back Cover Replacement, Loosen the back cover: step 2, image 1 of 3 Razer Blade 15" (2020) Back Cover Replacement, Loosen the back cover: step 2, image 2 of 3 Razer Blade 15" (2020) Back Cover Replacement, Loosen the back cover: step 2, image 3 of 3
      • The back cover is lightly secured to the motherboard by thermal pads. Depending on the age of your laptop, it may be easier or harder to remove.
      • Use a finger to pry up the right side of the back cover, starting at the Ethernet port cutout.
      Ask FixBot
    3. Razer Blade 15" (2020) Back Cover Replacement, Remove the back cover: step 3, image 1 of 3 Razer Blade 15" (2020) Back Cover Replacement, Remove the back cover: step 3, image 2 of 3 Razer Blade 15" (2020) Back Cover Replacement, Remove the back cover: step 3, image 3 of 3
      • Remove the back cover slowly, as to avoid tearing the thermal pads underneath.
      • Lay the back cover down on its rubber feet to avoid damaging the thermal pads on its underside.
      Ask FixBot
Clay Eickemeyer
107,986 Reputation
472 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
61,972 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 77
All Time: 1,098
