Razer Blade 15" (2018) Speakers Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
44
All Time:
764
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace one or both of the speakers in your Razer Blade 15" (2018).
If your speakers sound crackly, like static, or are silent, they might be damaged and in need of replacement.
Note: This guide will refer to the speakers by their true stereo side (indicated by "L" and "R" on the speakers) of the laptop, and not their orientation as you repair your laptop.
Tools
    1. Razer Blade 15" (2018) Speakers Replacement, Prepare your laptop for disassembly: step 1, image 1 of 2 Razer Blade 15" (2018) Speakers Replacement, Prepare your laptop for disassembly: step 1, image 2 of 2
      • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
      • Unplug all cables, fully shut down your laptop, and close the lid.
      Ask FixBot
    1. Razer Blade 15" (2018) Speakers Replacement, Unfasten the back cover: step 2, image 1 of 1
      • Rotate your laptop so the screen hinge is farthest from you.
      • Use a Torx T5 driver to remove the ten 3.8 mm-long screws securing the back cover.
      Ask FixBot
    2. Razer Blade 15" (2018) Speakers Replacement, Insert an opening pick: step 3, image 1 of 3 Razer Blade 15" (2018) Speakers Replacement, Insert an opening pick: step 3, image 2 of 3 Razer Blade 15" (2018) Speakers Replacement, Insert an opening pick: step 3, image 3 of 3
      • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If the cover feels loose, remove it at any time.
      • Apply a suction handle to the right edge of the back cover, between the middle screws and the screws closest to you.
      • Pull up on the suction handle to create a small gap between the back cover and the frame.
      • Insert an opening pick into the gap.
      Ask FixBot
    3. Razer Blade 15" (2018) Speakers Replacement, Angle the opening pick: step 4, image 1 of 3 Razer Blade 15" (2018) Speakers Replacement, Angle the opening pick: step 4, image 2 of 3 Razer Blade 15" (2018) Speakers Replacement, Angle the opening pick: step 4, image 3 of 3
      • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
      • Insert your pick up to 10 mm (0.4 in) deep.
      Ask FixBot
    4. Razer Blade 15" (2018) Speakers Replacement, Free the bottom right corner: step 5, image 1 of 3 Razer Blade 15" (2018) Speakers Replacement, Free the bottom right corner: step 5, image 2 of 3 Razer Blade 15" (2018) Speakers Replacement, Free the bottom right corner: step 5, image 3 of 3
      • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
      Ask FixBot
    5. Razer Blade 15" (2018) Speakers Replacement, Free the front edge: step 6, image 1 of 3 Razer Blade 15" (2018) Speakers Replacement, Free the front edge: step 6, image 2 of 3 Razer Blade 15" (2018) Speakers Replacement, Free the front edge: step 6, image 3 of 3
      • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame.
      Ask FixBot
    6. Razer Blade 15" (2018) Speakers Replacement, Remove the back cover: step 7, image 1 of 3 Razer Blade 15" (2018) Speakers Replacement, Remove the back cover: step 7, image 2 of 3 Razer Blade 15" (2018) Speakers Replacement, Remove the back cover: step 7, image 3 of 3
      • Remove the back cover.
      • Lay the back cover down on its rubber feet to avoid damaging the gray thermal pads on its underside.
      Ask FixBot
    1. Razer Blade 15" (2018) Speakers Replacement, Soften the battery cable tape adhesive: step 8, image 1 of 2 Razer Blade 15" (2018) Speakers Replacement, Soften the battery cable tape adhesive: step 8, image 2 of 2
      • Apply a heated iOpener to the battery cable tape for one minute.
      • You can also use a hair dryer—but be careful, as overheating the battery may damage it or create a fire hazard.
      Ask FixBot
    2. Razer Blade 15" (2018) Speakers Replacement, Peel up the battery cable tape: step 9, image 1 of 3 Razer Blade 15" (2018) Speakers Replacement, Peel up the battery cable tape: step 9, image 2 of 3 Razer Blade 15" (2018) Speakers Replacement, Peel up the battery cable tape: step 9, image 3 of 3
      Tool used on this step:
      Buy
      • Be careful not to damage the battery with your tool.
      • Use blunt nose tweezers or your fingers to peel the battery cable tape away from the cable.
      Ask FixBot
    3. Razer Blade 15" (2018) Speakers Replacement, Disconnect the battery: step 10, image 1 of 3 Razer Blade 15" (2018) Speakers Replacement, Disconnect the battery: step 10, image 2 of 3 Razer Blade 15" (2018) Speakers Replacement, Disconnect the battery: step 10, image 3 of 3
      • Use the point of a spudger to press on alternating sides of the battery connector and walk it out of its socket.
      Ask FixBot
    1. Razer Blade 15" (2018) Speakers Replacement, Disconnect the left speaker: step 11, image 1 of 3 Razer Blade 15" (2018) Speakers Replacement, Disconnect the left speaker: step 11, image 2 of 3 Razer Blade 15" (2018) Speakers Replacement, Disconnect the left speaker: step 11, image 3 of 3
      • If you're only replacing the right speaker, skip the next three steps.
      • Use the point of a spudger to push on alternating sides of the left speaker connector to "walk" it out of its socket.
      Ask FixBot
    2. Razer Blade 15" (2018) Speakers Replacement, Unfasten the left speaker: step 12, image 1 of 1
      • Use a Phillips screwdriver to remove the two 7.6 mm screws securing the left speaker.
      • Rubber grommets hold these screws in place. If the screws don't come out, just fully loosen them.
      Ask FixBot
    3. Razer Blade 15" (2018) Speakers Replacement, Remove the left speaker: step 13, image 1 of 2 Razer Blade 15" (2018) Speakers Replacement, Remove the left speaker: step 13, image 2 of 2
      • Remove the left speaker.
      Ask FixBot
    4. Razer Blade 15" (2018) Speakers Replacement, Disconnect the right speaker: step 14, image 1 of 3 Razer Blade 15" (2018) Speakers Replacement, Disconnect the right speaker: step 14, image 2 of 3 Razer Blade 15" (2018) Speakers Replacement, Disconnect the right speaker: step 14, image 3 of 3
      • If you only needed to replace the left speaker, skip the next three steps.
      • Use the point of your spudger to push on alternating sides of the right speaker connector to "walk" it out of its socket.
      Ask FixBot
    5. Razer Blade 15" (2018) Speakers Replacement, Unfasten the right speaker: step 15, image 1 of 1
      • Use a Phillips screwdriver to remove the two 7.6 mm screws securing the right speaker.
      Ask FixBot
    6. Razer Blade 15" (2018) Speakers Replacement, Remove the right speaker: step 16, image 1 of 2 Razer Blade 15" (2018) Speakers Replacement, Remove the right speaker: step 16, image 2 of 2
      • Remove the right speaker.
      Ask FixBot
    7. Razer Blade 15" (2018) Speakers Replacement, Reassembly information: step 17, image 1 of 2 Razer Blade 15" (2018) Speakers Replacement, Reassembly information: step 17, image 2 of 2
      • During reassembly, make sure the rubber grommets are in place at each screw cutout.
      Ask FixBot
Clay Eickemeyer
108,115 Reputation
471 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,132 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 44
All Time: 764
