Razer Blade 15 Motherboard Replacement
    1. Razer Blade 15 Motherboard Replacement, Remove the Back Cover: step 1, image 1 of 1
      • Flip over to the back side of the laptop
      • Remove the 10 screws at the bottom of the Razer using a T5 screwdriver head
      Ask FixBot
    2. Razer Blade 15 Motherboard Replacement, Remove the Laptop Battery: step 2, image 1 of 1
      • Unplug the battery and wear the anti-static band before proceeding
      • Unscrew the six Philips screws around the battery and lift the battery
      Ask FixBot
    3. Razer Blade 15 Motherboard Replacement, Remove the SSD: step 3, image 1 of 1
      • Find the SSD and unscrew the single screw
      • Once it is unscrewed, the SSD will pop up on one side
      • Carefully remove the SSD and place it to the side
      Ask FixBot
    4. Razer Blade 15 Motherboard Replacement, Disconnect the MOBO Cables: step 4, image 1 of 1
      • Locate the two display cables to the left of the left speaker and disconnect both. (one is underneath the other)
      • Locate and disconnect the four cables
      • Disconnect one cable that is underneath the SSD
      • Disconnect another cable that is next to the right fan
      • Disconnect the final two cables that are to the left of the battery connector
      Ask FixBot
    5. Razer Blade 15 Motherboard Replacement, Remove the RAM and Wi-Fi Card: step 5, image 1 of 1
      • Move the two metal pieces to each side and remove the two RAM
      • Disconnect the two thin cables connected to the Wi-Fi card
      • Remove the screw and carefully pull out the Wi-Fi card
      Ask FixBot
    6. Razer Blade 15 Motherboard Replacement, Remove the Fans and Speakers: step 6, image 1 of 1
      • Unscrew the four screws on the fans (two screws on each)
      • Make sure to unplug the connector on each of the fans. Lift and remove the fans.
      • Unscrew the four screws on the speakers (two screws on each)
      • Make sure to unplug the connector on each of the speakers and place them to the side
      Ask FixBot
    7. Razer Blade 15 Motherboard Replacement, Remove the Motherboard and Hinges: step 7, image 1 of 1
      • Remove the two screws on each hinge and pick up the black pieces
      • Locate the seven screws holding down the motherboard and remove them
      • Remove the plastic headphone jack cover
      • Lift up the MOBO and place it to the side
      • Be careful when handling the motherboard and make sure you’re wearing the anti-static band.
      Ask FixBot
      • Make sure all of the cables are in sight once the motherboard has been placed down
      • Screw in both the motherboard screws and the hinges
      • Reconnect the motherboard connectors
      • Make sure you reconnect the Wi-Fi card and RAM
      • Place and screw in the fans and speakers
      • Make sure the SSD has been reconnected and screwed in
      • Screw the battery back in and reconnect the battery
      • Update DMI Info
      Ask FixBot
Once the repair had been done. Call the user and let them know their laptop is ready for pick-up
4 other people completed this guide.
Ved Pitre
1,308 Reputation
5 Guides authored
4 Guide Comments
does anyone know the size of the case screws
kody benard - Reply Share
Anyone know the item number for a razer blade 15 2021 3060?
D Costa - Reply Share
How to remove the vapor chamber? I'd like to repaste the GPU. I saw image of removed vapor chamber without removing much aside from battery.
With battery removed, display cable disconnected, screws of vapor chamber removed, it cannot be easily lift off, did i need to remove more? Or it's just old thermal paste sticking too much?
Patrick - Reply Share
I cant seem to update the DMI info. I have no clue how to go about it, and no matter what I do, it will not read my gpu. everything else works fine.
Jaden Stepeck - Reply Share
Past 24 Hours: 7
Past 7 Days: 46
Past 30 Days: 176
All Time: 21,493
