Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
6
Past 7 Days:
30
Past 30 Days:
91
All Time:
1,226
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 - 35 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace a broken left fan in your Razer Blade 15 Advanced Model (Early 2020) laptop.
The left fan is on the same side as the charging port.
You may need to replace the fan if your laptop is overheating.
Tools
    1. Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Prepare your laptop for disassembly: step 1, image 1 of 2 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Prepare your laptop for disassembly: step 1, image 2 of 2
      • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
      • Unplug all cables, fully shut down your laptop, and close the lid.
      Ask FixBot
    1. Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Unfasten the back cover: step 2, image 1 of 2 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Unfasten the back cover: step 2, image 2 of 2
      • Use a T5 Torx driver to remove the ten 3.8 mm‑long screws securing the back cover.
      Ask FixBot
    2. Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Insert an opening pick: step 3, image 1 of 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Insert an opening pick: step 3, image 2 of 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Insert an opening pick: step 3, image 3 of 3
      • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If it feels loose, remove it at any time.
      • Apply a suction handle to the middle of the back cover's right edge, between the lower rubber foot and the middle screws.
      • Pull up on the suction handle to create a small gap between the back cover and the frame.
      • Insert an opening pick into the gap.
      Ask FixBot
    3. Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Angle the opening pick: step 4, image 1 of 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Angle the opening pick: step 4, image 2 of 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Angle the opening pick: step 4, image 3 of 3
      • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
      Ask FixBot
    4. Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Free the bottom right corner: step 5, image 1 of 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Free the bottom right corner: step 5, image 2 of 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Free the bottom right corner: step 5, image 3 of 3
      • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
      Ask FixBot
    5. Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Free the front edge: step 6, image 1 of 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Free the front edge: step 6, image 2 of 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Free the front edge: step 6, image 3 of 3
      • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame completely.
      Ask FixBot
    6. Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Remove the back cover: step 7, image 1 of 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Remove the back cover: step 7, image 2 of 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Remove the back cover: step 7, image 3 of 3
      • Remove the back cover.
      • Lay the back cover down on its rubber feet to avoid damaging the thermal pads.
      Ask FixBot
    1. Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Disconnect the battery: step 8, image 1 of 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Disconnect the battery: step 8, image 2 of 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Disconnect the battery: step 8, image 3 of 3
      • Insert the point of a spudger under the middle of the battery connector's long edge.
      • Lift and disconnect the battery press connector from its socket on the motherboard.
      • This will require some force. Don't pry against any resistors or chips.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      Ask FixBot
    1. Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Reposition the cables: step 9, image 1 of 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Reposition the cables: step 9, image 2 of 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Reposition the cables: step 9, image 3 of 3
      • The left fan will be on your right-hand side when working on the laptop, as it's laying upside down.
      • Use a spudger or your fingers to guide the Wi‑Fi card cables out of their clip on the top right corner of the fan.
      • Move the cables toward the right edge of the laptop and out of the way of the fan.
      Ask FixBot
    2. Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Disconnect the left fan: step 10, image 1 of 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Disconnect the left fan: step 10, image 2 of 3 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Disconnect the left fan: step 10, image 3 of 3
      Ask FixBot
    3. Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Unfasten the left fan: step 11, image 1 of 2 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Unfasten the left fan: step 11, image 2 of 2
      Tool used on this step:
      Buy
      • Use a Phillips screwdriver to remove the two 5.3 mm‑long screws securing the left fan.
      • The fan screws may be covered with stickers. Pierce through them with your screwdriver or use tweezers to remove them.
      Ask FixBot
    4. Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Remove the fan: step 12, image 1 of 2 Razer Blade 15 Advanced Model (Early 2020) Left Fan Replacement, Remove the fan: step 12, image 2 of 2
      • Remove the left fan.
      Ask FixBot
Spencer Day
206,507 Reputation
1,266 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,882 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 30
Past 30 Days: 91
All Time: 1,226
