Up to 20% off select tools
Razer Blade 14" (2014) Screen Assembly Replacement
Views: 13K
View statistics:
Past 24 Hours:
3
Past 7 Days:
23
Past 30 Days:
113
All Time:
13,253
Comments: 9
3 comments on steps, 6 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
Swapping broken Razer Blade screen assembly with working one.
    1. Razer Blade 14" (2014) Screen Assembly Replacement, Screen Assembly: step 1, image 1 of 1
      • Start by making sure your replacement assembly will work with your model. I bought this QHD assembly on eBay. This assembly includes the LCD, webcam, antenna, and touch digitizer. Before embarking, one should make sure that that a new screen assembly is necessary and will fix their problem. In my case, my LCD and touchscreen were fried.
      Ask FixBot
    2. Razer Blade 14" (2014) Screen Assembly Replacement: step 2, image 1 of 1
      • unscrew the 10 (T5) torx screws to release the back panel. Be sure to fully drain your laptops battery or disconnect the battery before tampering with the internal components.
      Ask FixBot
    3. Razer Blade 14" (2014) Screen Assembly Replacement: step 3, image 1 of 1
      • Note the LCD Cable (Green), Antenna Cable (Red), Webcam Cable (Blue), and Charging cable (Purple). These all run to the screen assembly.
      Ask FixBot
    4. Razer Blade 14" (2014) Screen Assembly Replacement: step 4, image 1 of 1
      • Unplug before mentioned connectors. The webcam and charger cable may require a small pry tool. The LCD cable should disconnect with a light pull on the plastic tab. The antenna cables just pop off with some upward pressure.
      Ask FixBot
    5. Razer Blade 14" (2014) Screen Assembly Replacement: step 5, image 1 of 1
      • Unscrew Phillips head screws holding screen hinge.
      Ask FixBot
    6. Razer Blade 14" (2014) Screen Assembly Replacement: step 6, image 1 of 1
      • Unscrew right side screws, (you have to lift the charging port out of the case to fully release the hinge)
      Ask FixBot
    7. Razer Blade 14" (2014) Screen Assembly Replacement: step 7, image 1 of 1
      • After removing screws, work the screen assembly free from the case.
      Ask FixBot
    8. Razer Blade 14" (2014) Screen Assembly Replacement: step 8, image 1 of 1
      • Old screen.
      Ask FixBot
    9. Razer Blade 14" (2014) Screen Assembly Replacement: step 9, image 1 of 1
      • Lower case onto replacement screen, Making sure no cables get pinched in the hinge.
      Ask FixBot
    10. Razer Blade 14" (2014) Screen Assembly Replacement: step 10, image 1 of 1
      • Reconnect cables. (Route these cables in a way that would prevent getting crushed against the bottom cover)
      Ask FixBot
    11. Razer Blade 14" (2014) Screen Assembly Replacement: step 11, image 1 of 1
      • Replace bottom cover and check for functionality! (Markers are to protect identity of my friends and I)
      Ask FixBot
Finish Line
2 other people completed this guide.
Author
with
Sellers Hill
128 Reputation
1 Guide authored
6 Guide Comments
Just preformed the repair today with success!
The total repair took me about 30 minutes. I would suggest anyone doing this repair to buy a can of air before starting — I was amazed at how dirty my machine was under the case.
Many thanks for sharing this guide.
Caleb Dowdy - Reply Share
can you share the ebay link thanks
ALI AL-Hashmi - Reply Share
Is it possible to swap the matte screen with the glass touch screen
Kevin Chan - Reply Share
Hi i try to do this in mi razer blade 14 2017…. the model is same, spare part and all connectors are the same, but when i turn on the laptop screen is black… the logo in the back of the screen is turn on also the touch works… i plugged a monitor to the laptop and works… i touch the screen in the laptop and see it works on the monitor….
when i go to settings and try to identify screens, cant see the screen of the laptop (default) as available.
I disable and enable the drivers (device manager) both graphic cards nothing happens.
I notice the connector has this number CA12020569TH is the same in both screens (i assume was part number), but down of this number connectors had a different number, spare part is 7AR01A7 (i assume was serial num) the original i don’t have it, i re install the broken screen,
Can you help me please, the spare part is a full assembly like the one in this post. Thanks for you time if you read this and best Regards
Tomas Gerardo Thomas Paz - Reply Share
Hi Tomas Gerado,
I have the same problem. Have you solved the problem yet? Please share your experience.
Thank you,
Vinh PHAM GIA - Reply Share
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 113
All Time: 13,253
