Community-Contributed Guide
Introduction
Go to step 1 ↓I Intend to show you how to safely remove the battery.
Tools
Spudger4.9
Flip the hold down up
Remove the cable
Repeat for second cable
Use a spudger to disconnect the plug from the connector by pulling it away from the socket, parallel to the board.
Bend the connector backwards to prevent it from getting in the way of the motherboard.
Remove the battery by pulling up from the side closest to the motherboard
21 other people completed this guide.
17 Guide Comments
i want buy a battery for razer blade but I can't buy it anywhere
Please help me, my battery only 20% heathly
May I have a detailed guide on how you remove the cable over the battery, please? I am not used to taking machines apart, and wouldn't want to risk ruining my laptop. (didn't quite understand your pictures)
The only way to remove the cable is to work it out with a set of tweezers and be gentle not to pull the cables lose from the connector.
