Razer Blackwidow V3 Pro Battery Replacement
    1. Razer Blackwidow V3 Pro Battery Replacement, Turn off keyboard: step 1, image 1 of 2 Razer Blackwidow V3 Pro Battery Replacement, Turn off keyboard: step 1, image 2 of 2
      • Turn off your keyboard
      • Make sure that no lights on the keyboard are on
      Ask FixBot
    2. Razer Blackwidow V3 Pro Battery Replacement, Pull all keycaps off: step 2, image 1 of 3 Razer Blackwidow V3 Pro Battery Replacement, Pull all keycaps off: step 2, image 2 of 3 Razer Blackwidow V3 Pro Battery Replacement, Pull all keycaps off: step 2, image 3 of 3
      • Remove the keycaps using either a keycap puller or your hands
      • If you are not using a keycap puller, take caution to only pull the keycaps directly up or you may risk damage. Remove keycaps near the outskirts of the keyboard first, then work your way to the middle.
      • Repeat until all keycaps are off
      Ask FixBot
    1. Razer Blackwidow V3 Pro Battery Replacement, Peeling the Rubber Feet: step 3, image 1 of 2 Razer Blackwidow V3 Pro Battery Replacement, Peeling the Rubber Feet: step 3, image 2 of 2
      • Peel the lower-right rubber feet off just enough to reveal the 9mm Phillips screw.
      • This image turns the keyboard backwards, which is why the rubber feet we are peeling off appears to be on top. If it helps, turn your keyboard backwards too.
      • Be careful as to not rip the rubber feet. If needed, apply an iOpener, heat gun, or hair dryer on the rubber pad to soften the adhesive underneath.
      Ask FixBot
    2. Razer Blackwidow V3 Pro Battery Replacement, Unscrewing under the Rubber Feet: step 4, image 1 of 1
      • Unscrew the 9 mm Phillips screw underneath.
      Ask FixBot
    3. Razer Blackwidow V3 Pro Battery Replacement, Remove front screws: step 5, image 1 of 2 Razer Blackwidow V3 Pro Battery Replacement, Remove front screws: step 5, image 2 of 2
      • Remove the 15 7 mm Phillips screws
      Ask FixBot
    4. Razer Blackwidow V3 Pro Battery Replacement, Open the keyboard: step 6, image 1 of 3 Razer Blackwidow V3 Pro Battery Replacement, Open the keyboard: step 6, image 2 of 3 Razer Blackwidow V3 Pro Battery Replacement, Open the keyboard: step 6, image 3 of 3
      • Lift the top of the keyboard up and slightly to the front.
      • While pushing up, watch the LED on the front (circled red on the 2nd picture) and make sure it doesn't get damaged while removing the lid.
      • Do not remove the keyboard entirely, there are two connectors still in place.
      Ask FixBot
    5. Razer Blackwidow V3 Pro Battery Replacement, ZIF connector removal: step 7, image 1 of 3 Razer Blackwidow V3 Pro Battery Replacement, ZIF connector removal: step 7, image 2 of 3 Razer Blackwidow V3 Pro Battery Replacement, ZIF connector removal: step 7, image 3 of 3
      • Flip up the black locking flap on the ZIF connector using a fingernail or a spudger, then carefully pull out the ribbon cable.
      • During reassembly, try not to bend the ribbon cable, apart from the factory made bend.
      Ask FixBot
    6. Razer Blackwidow V3 Pro Battery Replacement, Wire removal: step 8, image 1 of 2 Razer Blackwidow V3 Pro Battery Replacement, Wire removal: step 8, image 2 of 2
      • Carefully pull out the wires.
      • You may need to wiggle the wires in order to remove them.
      • During reassembly, make sure that you don't assemble these wires backwards, or you may risk damage.
      • Remove the top housing entirely.
      Ask FixBot
    1. Razer Blackwidow V3 Pro Battery Replacement, Peel off casing: step 9, image 1 of 3 Razer Blackwidow V3 Pro Battery Replacement, Peel off casing: step 9, image 2 of 3 Razer Blackwidow V3 Pro Battery Replacement, Peel off casing: step 9, image 3 of 3
      • Peel off the black plastic covering the battery.
      • Peel off the black plastic piece carefully to make sure the battery doesn't get punctured and release dangerous chemicals.
      Ask FixBot
    2. Razer Blackwidow V3 Pro Battery Replacement, Battery Connector.: step 10, image 1 of 3 Razer Blackwidow V3 Pro Battery Replacement, Battery Connector.: step 10, image 2 of 3 Razer Blackwidow V3 Pro Battery Replacement, Battery Connector.: step 10, image 3 of 3
      • Remove the battery connector from the motherboard.
      • You may need to wiggle the connector in order to remove it.
      • During reassembly, make sure to insert the connector back the right way, or you may risk damaging the connector.
      Ask FixBot
    3. Razer Blackwidow V3 Pro Battery Replacement, Removing the wire: step 11, image 1 of 3 Razer Blackwidow V3 Pro Battery Replacement, Removing the wire: step 11, image 2 of 3 Razer Blackwidow V3 Pro Battery Replacement, Removing the wire: step 11, image 3 of 3
      Tool used on this step:
      Buy
      • Use your hands or tweezers to remove the wires from the mount.
      Ask FixBot
    4. Razer Blackwidow V3 Pro Battery Replacement, Battery Information: step 12, image 1 of 1
      • The battery is held on with adhesive in the middle, as highlighted. direct your iOpener / heating device, and your tools in this general area to remove the battery.
      Ask FixBot
    5. Razer Blackwidow V3 Pro Battery Replacement, Heating instructions: step 13, image 1 of 2 Razer Blackwidow V3 Pro Battery Replacement, Heating instructions: step 13, image 2 of 2
      • Heat and place an iOpener or other heating device (Hair Dryer / Heat Gun) under the general location of the battery's adhesive.
      • Don't apply too much heat to the battery, use the iOpener for about a minute on the battery maximum
      • For your reference, the red box is the general location of where the adhesive of the battery is.
      • For your reference, the black box is where the iOpener is.
      Ask FixBot
    6. Razer Blackwidow V3 Pro Battery Replacement, Adhesive cutting: step 14, image 1 of 2 Razer Blackwidow V3 Pro Battery Replacement, Adhesive cutting: step 14, image 2 of 2
      • Go slow, and reheat if the adhesive is still too sticky (Just don't overheat the battery). Do not puncture the battery, or you risk a dangerous situation. If you are using a heat gun or hair dryer, plan in case of a fire.
      • Use a spudger to cut the adhesive, or if you have a suction cup, you can pull the battery directly up without risking puncturing the battery.
      • Avoid bending the battery.
      Ask FixBot
    7. Razer Blackwidow V3 Pro Battery Replacement, (iFixit opening tool only) Lifting the battery out: step 15, image 1 of 2 Razer Blackwidow V3 Pro Battery Replacement, (iFixit opening tool only) Lifting the battery out: step 15, image 2 of 2
      • Use an iFixit opening tool (or flat end of your spudger) to lift the battery up.
      • Prevent bending of the battery and only apply pressure periodically. Reheat if needed.
      Ask FixBot
    8. Razer Blackwidow V3 Pro Battery Replacement, Remove the battery: step 16, image 1 of 3 Razer Blackwidow V3 Pro Battery Replacement, Remove the battery: step 16, image 2 of 3 Razer Blackwidow V3 Pro Battery Replacement, Remove the battery: step 16, image 3 of 3
      • Remove the battery carefully.
      Ask FixBot
Recycle responsibly, it may be the law in your area.
Make sure to calibrate your battery.
op_
540 Reputation
3 Guides authored
5 Guide Comments
I didn't attach a battery in the parts section for a reason. I found one site selling the exact same model number for the Razer BlackWidow V3 Pro battery, but it was from a site I've never seen before and zero reviews on trustpilot. I'll attach it here just in case, but buying it is at your own risk and you may not get what you ordered.
FT5936E2P Battery Replacement For Razer RZ03-0282 Wireless Keyboard (anvone.com)
op_ - Reply Share
I really don't know who is going to use this, but here's their battery supplier for who it becomes useful to (Although I don't take responsibility to if this source is reliable or not, it was just a quick Google search :))
op_ - Reply Share
Any idea where to get a New battery from a trustable seller ? Thanks !
Max HBland - Reply Share
What are the dimensions of the original battery?
What do the 3 wires connect to?
Would a larger battery fit?
O.N. - Reply Share
Anvone appears to be located in Shenzhen, which is a good place to buy model specific OEM stuff.
Evan M. Fabiano - Reply Share
Past 24 Hours: 5
Past 7 Days: 42
Past 30 Days: 148
All Time: 4,792
