Introduction
If your Razer BlackWidow V3 Tenkeyless keyboard is experiencing unresponsive or damaged keys, this switch replacement guide will help you restore full functionality. Since the switches are an integral part of the keyboard’s performance, replacing them can resolve many common issues. For this guide, you will need a keycap puller, a soldering iron, desoldering pump or wick, and replacement switches compatible with your keyboard. The steps are straightforward, but involve basic soldering—so be sure to follow each instruction carefully.
Before you start, unplug the keyboard from your computer to prevent accidental damage.
Use a keycap puller remove all keycaps.
1 Guide Comment
To remove the switches after desoldering you will need to gently push on the black circle (bottom of the switch) near the 2 pins. This pops the switch out.
If its too hard to push the switch out consider using the tip of the soldering iron to push the pins to the middle of the whole in the circuit board to make sure its not being held on by left over solder.
