Razer BlackWidow V3 Tenkeyless LED Replacement
  1. Razer BlackWidow V3 Tenkeyless LED Replacement, LED: step 1, image 1 of 1
    • Before you start, unplug the keyboard from your computer to prevent accidental damage.
    • Use a keycap puller to all keycaps.
    Ask FixBot
  2. Razer BlackWidow V3 Tenkeyless LED Replacement: step 2, image 1 of 1
    • Gently remove the 7.85 mm screws that secure the case with a Phillips #0 screwdriver.
    • Avoid applying excessive force.
    Ask FixBot
  3. Razer BlackWidow V3 Tenkeyless LED Replacement: step 3, image 1 of 2 Razer BlackWidow V3 Tenkeyless LED Replacement: step 3, image 2 of 2
    • Carefully separate the backplate from the main keyboard body.
    • A plastic opening tool can be helpful to gently pry the pieces apart if needed.
    • Be patient and work slowly to avoid breaking any clips or the usb-connector.
    Ask FixBot
  4. Razer BlackWidow V3 Tenkeyless LED Replacement: step 4, image 1 of 2 Razer BlackWidow V3 Tenkeyless LED Replacement: step 4, image 2 of 2
    • Gently pull out the cable holding the usb connector using your hand.
    • Ensure the cable is pulled straight back to prevent the usb-connector snapping.
    Ask FixBot
  5. Razer BlackWidow V3 Tenkeyless LED Replacement: step 5, image 1 of 2 Razer BlackWidow V3 Tenkeyless LED Replacement: step 5, image 2 of 2
    • Use a soldering iron to heat the four solder points securing the LED to the board, then apply a solder wick to absorb and remove the melted solder.
    • The soldering process involves high heat—handle the soldering iron carefully to avoid burns or damage to the circuit board.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 68
All Time: 743
