Razer BlackWidow Chroma Back Panel Replacement
  1. Razer BlackWidow Chroma Back Panel Replacement, Rubber Feet: step 1, image 1 of 2 Razer BlackWidow Chroma Back Panel Replacement, Rubber Feet: step 1, image 2 of 2
    • Turn the keyboard over so that it is lying flat on its face.
    • Use the iFixit opening tool to pry the rubber feet off the keyboard.
    Ask FixBot
  2. Razer BlackWidow Chroma Back Panel Replacement, Front Panel: step 2, image 1 of 2 Razer BlackWidow Chroma Back Panel Replacement, Front Panel: step 2, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard.
    • Use an opening tool as a wedge between the front and back panel to pry open the front panel.
    • If the front and back panel won't separate, DO NOT use excessive force. This may result in damaging the keyboard.
    • Instead, slide the opening tool across the keyboard in between the front and back panel. Go around the edges of the keyboard until the panels disconnect.
    • Flip the keyboard over so the keys are facing up.
    • Grabbing the left and right lips of the front panel, lift both ends up, removing the front panel.
    Ask FixBot
  3. Razer BlackWidow Chroma Back Panel Replacement, Back Panel: step 3, image 1 of 1
    • Using a Phillips #1 screwdriver, remove all ten screws found along the outer edges of the keyboard.
    Ask FixBot
  4. Razer BlackWidow Chroma Back Panel Replacement: step 4, image 1 of 1
    • Insert the Jimmy along the edges of the back panel and remove the back panel from the device.
    Ask FixBot
1 Guide Comment
Lacks details on where the clips are. It resulted in prying an area where there was one and it broke. We need updated images with those details. If I can I will do do when I reassemble.
Kellic Normand - Reply Share
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 70
All Time: 6,421
