Razer Basilisk V3 Skates Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
46
Past 30 Days:
234
All Time:
2,351
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Mouse skates wear down over time due to continuous use, which can lead to increased friction and bumpy movement. Replacing old skates is a simple fix to improve user experience and extend the life of the Razer Basilisk V3. Additionally, replacing the stock skates of the Razer Basilisk V3 with higher quality material, such as PTFE skates, can yield increased speed/control. Regardless, this guide will explain the removal and replacement of the Basilisk's mouse skates.
Tools
  • Heat Gun
    $29.99
    4.7
  • Spudger
    4.9
    1. Razer Basilisk V3 Skates Replacement, Skates: step 1, image 1 of 1
      • Locate the highlighted white skates on the bottom of the mouse.
      Ask FixBot
    2. Razer Basilisk V3 Skates Replacement: step 2, image 1 of 3 Razer Basilisk V3 Skates Replacement: step 2, image 2 of 3 Razer Basilisk V3 Skates Replacement: step 2, image 3 of 3
      • Heat the skate using a heat gun or hair dryer.
      • Using the pointy end of the spudger pry away a corner of the skate.
      • If the adhesive does not pull away easily, heat the skate more.
      • Once the corner of the skate comes free use the flat end of the spudger to peel off the rest of the skate.
      • Repeat these steps for each of the skates.
      Ask FixBot
To replace the skates heat the new skates until the adhesive is sticky. Then apply to the appropriate space.
Sarah
237 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 46
Past 30 Days: 234
All Time: 2,351
