Razer Barracuda X Volume Control Knob Replacement
  1. Razer Barracuda X Volume Control Knob Replacement, Battery: step 1, image 1 of 3 Razer Barracuda X Volume Control Knob Replacement, Battery: step 1, image 2 of 3 Razer Barracuda X Volume Control Knob Replacement, Battery: step 1, image 3 of 3
    • Remove the cushion by pulling it off from the edge and out from the grooves.
    • Continue to pull the cushion away from the speaker until the cushion is fully separated.
    Ask FixBot
  2. Razer Barracuda X Volume Control Knob Replacement: step 2, image 1 of 1
    • Remove the four 6 mm Phillips #1 screws from the left side of the speaker casing.
    Ask FixBot
  3. Razer Barracuda X Volume Control Knob Replacement: step 3, image 1 of 2 Razer Barracuda X Volume Control Knob Replacement: step 3, image 2 of 2
    • Gently pull the speaker casing away from the shell.
    • Place it face down to access the battery.
    Ask FixBot
  4. Razer Barracuda X Volume Control Knob Replacement: step 4, image 1 of 2 Razer Barracuda X Volume Control Knob Replacement: step 4, image 2 of 2
    • Unplug the battery from the socket.
    • Use a spudger to gently lift the battery up.
    • Remove the battery.
    Ask FixBot
  5. Razer Barracuda X Volume Control Knob Replacement, Ear Pad: step 5, image 1 of 1
    • Remove the old cushion by pulling it off from the edge and out from the grooves.
    Ask FixBot
  6. Razer Barracuda X Volume Control Knob Replacement: step 6, image 1 of 1
    Ask FixBot
  7. Razer Barracuda X Volume Control Knob Replacement, Microphone: step 7, image 1 of 1
    • Unplug the microphone from the headset.
    Ask FixBot
  8. Razer Barracuda X Volume Control Knob Replacement, Volume Control Knob: step 8, image 1 of 1
    • Remove four 6 mm Phillips #1 screws that secure the cover.
    • Lift off the cover.
    Ask FixBot
  9. Razer Barracuda X Volume Control Knob Replacement: step 9, image 1 of 1
    • Remove the single 6 mm Phillips screws that secures the volume control knob.
    Ask FixBot
  10. Razer Barracuda X Volume Control Knob Replacement: step 10, image 1 of 1
    • Remove the volume control knob.
    Ask FixBot
4 Guide Comments
Right ear stops playing when I set volume to max, and crusting noises when I change the volume. I suppose it's because of dirty potentiometer, just going through these steps and cleaning it with alcohol should work right?
Kisoma - Reply Share
I've the exactly the same issue with you, I just removed the knob and sprey with first high pressure air then isopropyl alcohol, it's not completely fixed crusting noises they are still here but much more less that before also mine cuts the sound from the right side it's also fixed and for more better than before, I don't know how much holds but right now I'm happy :) Thanks for writer also.
Ali Demirkaya - Reply Share
Could you tell me where I can get a potentiometer for these headphones? 102b that they don’t fit on aliexpress because the sound from the parav is lost
Сергій Хлевнюк - Reply Share
could you tell me the measurements for the knob? Mine broke from being o tightened too much and use, so I wanted to 3d print a replacement
oviel rosario - Reply Share
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 92
All Time: 2,046
