Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓This guide shows how to replace the lenses of Ray-Ban Round Metal RB3447 sunglasses. The RB3447 has a thin, fully closed metal rim, so the lens is not press-fitted as in an acetate frame: each rim is closed by a tiny screw at the outer corner, in the block where the temple arm is hinged. You loosen that screw so the rim opens slightly, swap the lens and close the rim again.
Before you start, read the code printed on the inside of one of the temple arms, for example "RB3447 001 50â–¡21 145". RB3447 is the model, 001 the frame colour, 50 the lens width in millimetres, 21 the bridge and 145 the temple length. The RB3447 is made in three lens sizes (47, 50 and 53 mm) and a lens for one size will not fit another. The RB3447N looks almost the same but uses flatter lenses (base 2 instead of base 6), so its lenses are not interchangeable with the RB3447; the optical version RB3447V is a different frame too.
Replacement lenses for this frame exist as original Ray-Ban lenses, which carry the Ray-Ban logo on the right lens and an "RB" engraving on the left, and as compatible (non-original) lenses from independent manufacturers, which have no logo. Original RB3447 lenses are mineral glass, so work over a soft surface. We sell both types for this model in our workshop, by lens size: Ray-Ban RB3447 replacement lenses.
Video Overview
Video of the whole procedure.
Rest the glasses on a soft, light-coloured cloth, so that a lens or the tiny screw is not damaged or lost if it drops.
Hold the front firmly and locate the small screw at the outer corner of the rim, in the block next to the hinge of the temple arm.
With a precision screwdriver, turn the screw anticlockwise until the metal rim opens. On this frame it usually has to come out completely, so keep it on the cloth.
With the screw out, gently spread the two ends of the rim apart with your fingers, only a millimetre or two.
Push the lens out of the rim from the inside with your thumb.
Wipe the groove of the rim with the microfiber cloth to remove dust before fitting the new lens.
Check that the lens is for the correct side and fit it with the curved side facing outwards. On original lenses, the Ray-Ban logo goes on the right lens as worn, near the temple.
Seat the edge of the lens in the groove all the way round, starting from the nose side and finishing at the screw block.
Press the two ends of the rim together with your fingers and start the screw by hand, so that the thread catches straight.
Tighten the screw gently with the precision screwdriver until the rim is closed and the lens is held firmly. Do not overtighten: the thread in the screw block is small and strips easily.
Wiggle the lens with your fingers: it must not move or rotate in the rim.
Repeat steps 1 to 4 on the other side and clean both lenses with the microfiber cloth.
Replace one lens at a time: the other lens serves as a reference for the correct side and orientation. If the rim screw is lost or its thread is stripped, replace it with a matching eyewear screw rather than using glue.
