Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓This guide shows how to replace the lenses of Ray-Ban Clubmaster RB3016 sunglasses. The Clubmaster combines an acetate brow bar with a metal lower rim, so the lens is not press-fitted as in a Wayfarer: each lens is held by a small screw at the outer corner of the rim, under the brow bar. You loosen that screw, swap the lens and tighten it again.
Before you start, read the code printed on the inside of one of the temple arms, for example "RB3016 W0365 51â–¡21 145". RB3016 is the model, W0365 the colour, 51 the lens width in millimetres, 21 the bridge and 145 the temple length. The RB3016 is made in several lens sizes (49, 51 and 55 mm) and a lens for one size will not fit another. Other Clubmaster versions, such as the folding RB2176, the RB3507 Aluminum or the RB4354, look similar but take their own lenses.
Replacement lenses for this frame exist as original Ray-Ban lenses, which carry the Ray-Ban logo, and as compatible (non-original) lenses from independent manufacturers, which have no logo. Many RB3016 versions come with glass lenses, so work over a soft surface. We sell both types for this model in our workshop, by lens size: Ray-Ban Clubmaster RB3016 replacement lenses
Video Overview
Video of the whole procedure filmed in our workshop.
Rest the glasses on a soft, light-coloured cloth, so that a lens or the screw is not damaged or lost if it drops.
Each lens is held by a small screw at the outer corner of the front, under the acetate brow bar, where the metal lower rim meets it.
With a precision screwdriver, turn the screw anticlockwise just enough for the metal rim to open. It does not need to come out completely.
With the rim open, press gently on the lens from the inside with your thumbs until it comes out of the groove in the brow bar and the lower rim.
Before fitting the new lens, wipe the groove of the rim and of the brow bar with the cloth to remove dust.
Check that the lens is for the correct side and fit it with the curved side facing outwards. On original lenses, the Ray-Ban logo goes on the right lens as worn, near the temple.
Seat the edge of the lens in the groove of the brow bar first, then in the lower metal rim, all the way round.
Tighten the screw gently until the lens is held firmly. If the lens looks stressed or the screw is hard to turn, back it off a quarter turn.
Wiggle the lens with your fingers: it must not move or rotate. Repeat on the other side.
Replace one lens at a time: the other lens serves as a reference for the correct side and orientation. If the screw is lost or its thread is stripped, replace it with a matching eyewear screw rather than using glue.
