Ray-Ban Aviator RB3025 Temple Arm Replacement
View statistics:
Past 24 Hours:
6
Past 7 Days:
24
Past 30 Days:
46
All Time:
46
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide shows how to replace a temple arm (temple) on Ray-Ban Aviator RB3025 sunglasses. Each temple is attached to the metal front by a hinge with one screw.
The RB3025 is made in several lens sizes and colours. Read the code printed on the inside of the temple arm (for example RB3025 001 58□14) and take a photo of it before ordering, so that the new temple matches the frame.
Replacement temples are sold as original Ray-Ban temples and as compatible (non-original) temples without the Ray-Ban logo.
Video Overview
Video of the whole procedure filmed in our workshop.
    1. Ray-Ban Aviator RB3025 Temple Arm Replacement, Remove the hinge screw and the old temple: step 1, image 1 of 1
      • Open the glasses and rest them on a light-coloured cloth with the hinge in view.
      • Unscrew the hinge screw anticlockwise with a precision screwdriver and keep it safe.
      • Lift the old temple arm out of the hinge.
      Ask FixBot
    2. Ray-Ban Aviator RB3025 Temple Arm Replacement, Fit the new temple and adjust the tip: step 2, image 1 of 1
      • Place the new temple in the hinge with the holes lined up. The curved tip must point down and inwards, like the tip of the other temple.
      • Insert the screw and tighten it until the temple is held firmly but still opens and closes smoothly.
      • Try the glasses on. If one side sits differently, bend the temple tip gently, in small steps.
      • Overtightening makes the hinge stiff and can strip the screw.
      Ask FixBot
If you are replacing both temples, do one at a time: the temple still fitted shows the correct position and curve for the new one.
ReplacementLensesWorkshop
821 Reputation
13 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 24
Past 30 Days: 46
All Time: 46
