Up to 20% off select tools
Raspberry Pi Model B Revision 2.0 USB Port Replacement
Views: 4.2K
View statistics:
Past 24 Hours:
5
Past 7 Days:
26
Past 30 Days:
159
All Time:
4,164
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 50 minutes - 2 hours
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
If you've spent enough time exploring the wonderful uses of a Raspberry Pi (Model B Revision 2.0), then you may have explored enough to discover a faulty/broken USB port. No worries; a USB port replacement is an easy fix. First, you are going to need an adequate workspace and some knowledge of soldering/desoldering. Nothing fancy, just a well-ventilated space with clean, stable surfaces. If you do not already own a soldering iron, a fine-tipped model is recommended. Careful, the iron will be very hot; always make sure the iron cord is not in the way of your work.
If you decide to work outside, position yourself away from the wind; the fumes will remain out of your way. Also if you wear contact lenses you must remove them before soldering. If any fumes or debris were to intermingle with the lenses, they might get lodged and be difficult to remove.
Lastly, be patient. The estimated time is only a reference. If you have little or no experience with soldering, it might take some time to develop a rhythm. Also, if you find a technique that works for you, carry on. This is a learning experience, and a perfect port to practice on!
Caution: Soldering/desoldering presents a potential for device damage and burns. Always work in a well-ventilated area.
    1. Raspberry Pi Model B Revision 2.0 USB Port Replacement, USB Port: step 1, image 1 of 1
      Tool used on this step:
      Microfiber Cleaning Cloths
      $3.99
      Buy
      • Ensure that your workspace has adequate ventilation.
      • Clean your work area with a lint-resistant wipe.
      • A microfiber cloth is recommended, but not one you love! It will be used to clean flux later.
      Ask FixBot
    2. Raspberry Pi Model B Revision 2.0 USB Port Replacement: step 2, image 1 of 2 Raspberry Pi Model B Revision 2.0 USB Port Replacement: step 2, image 2 of 2
      • Preheat your soldering iron.
      • Preheating will take 2-4 minutes, depending on your model.
      • Wet a heat-resistant cleaning sponge and have it nearby.
      Ask FixBot
    3. Raspberry Pi Model B Revision 2.0 USB Port Replacement: step 3, image 1 of 2 Raspberry Pi Model B Revision 2.0 USB Port Replacement: step 3, image 2 of 2
      • Orient the Raspberry Pi so that the port-covered side faces downwards, and the opening of the USB port is visible.
      • Identify the 12 silver USB pins on the lower-middle section of the board.
      Ask FixBot
    4. Raspberry Pi Model B Revision 2.0 USB Port Replacement: step 4, image 1 of 3 Raspberry Pi Model B Revision 2.0 USB Port Replacement: step 4, image 2 of 3 Raspberry Pi Model B Revision 2.0 USB Port Replacement: step 4, image 3 of 3
      • Use an inexpensive paint brush, or the applicator that came with the flux, to apply flux around the 12 pins on the printed circuit board (PCB).
      • Be sure to coat flux on what you don’t want to be covered in solder.
      Ask FixBot
    5. Raspberry Pi Model B Revision 2.0 USB Port Replacement: step 5, image 1 of 2 Raspberry Pi Model B Revision 2.0 USB Port Replacement: step 5, image 2 of 2
      • Soldering/desoldering presents potential for device damage and burns.
      • Starting with the largest pins first, but individually, use the soldering iron to carefully melt the solder on each of the pins, with care not to damage the PCB.
      • You will need to keep the solder liquid throughout the next two steps. It's alright if it solidifies, but solder will not wick if it is not liquid.
      Ask FixBot
    6. Raspberry Pi Model B Revision 2.0 USB Port Replacement: step 6, image 1 of 3 Raspberry Pi Model B Revision 2.0 USB Port Replacement: step 6, image 2 of 3 Raspberry Pi Model B Revision 2.0 USB Port Replacement: step 6, image 3 of 3
      • Make a wire loop out of the desoldering braid to "soak up" the solder on the smaller pins. Hook the pin and place the soldering iron tip on the loop and pin simultaneously.
      • Use the desoldering braid to “soak up" the melted solder. If the braid will not catch more solder, cut off the end and continue to the smaller pins.
      • This will be the most time-consuming step and may take some practice to refine a technique that works for you. Keep pushing!
      Ask FixBot
    7. Raspberry Pi Model B Revision 2.0 USB Port Replacement: step 7, image 1 of 3 Raspberry Pi Model B Revision 2.0 USB Port Replacement: step 7, image 2 of 3 Raspberry Pi Model B Revision 2.0 USB Port Replacement: step 7, image 3 of 3
      • After all the solder securing the pins is removed, lightly heat each silver pin. Use a hemostat or needle-nose pliers to disconnect the smaller pins from the board.
      • Remove the faulty port with a gentle pull if necessary.
      • The metal casing of the port might be hot.
      Ask FixBot
    8. Raspberry Pi Model B Revision 2.0 USB Port Replacement: step 8, image 1 of 1
      • Clean the excess flux off the PCB with a microfiber cloth.
      Ask FixBot
    9. Raspberry Pi Model B Revision 2.0 USB Port Replacement: step 9, image 1 of 1
      • Insert the replacement port with the open side facing outwards.
      • The replacement part's pins might need a little jostling to be fully seated on the PCB.
      Ask FixBot
    10. Raspberry Pi Model B Revision 2.0 USB Port Replacement: step 10, image 1 of 2 Raspberry Pi Model B Revision 2.0 USB Port Replacement: step 10, image 2 of 2
      • Apply flux around the 12 USB pins on the PCB.
      Ask FixBot
    11. Raspberry Pi Model B Revision 2.0 USB Port Replacement: step 11, image 1 of 2 Raspberry Pi Model B Revision 2.0 USB Port Replacement: step 11, image 2 of 2
      • Melt a few millimeters of lead-free solder on the tip of the iron.
      • Bring the soldering iron with the melted solder close to the pin and its respective base. Slowly apply solder to a combination of the pin, pin-base, and the iron tip until the solder collects into a “bubble,” encapsulating the pin and base.
      Ask FixBot
    12. Raspberry Pi Model B Revision 2.0 USB Port Replacement: step 12, image 1 of 2 Raspberry Pi Model B Revision 2.0 USB Port Replacement: step 12, image 2 of 2
      • Repeat the previous step for the remaining pins.
      Ask FixBot
Your new USB port should be fully functional!
4 other people completed this guide.
Author
with
Tamren Lenn
268 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 159
All Time: 4,164
