Up to 20% off select tools
Raleigh M20 Handlebars Replacement
Views: 3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
102
All Time:
3,000
Comments: 0
Go to guide comments
Completed: 0
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 45 minutes
Difficulty: Moderate
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Better Introduction
Improve this guide by completing or revising its introduction.
    1. Raleigh M20 Handlebars Replacement, Handlebars: step 1, image 1 of 2 Raleigh M20 Handlebars Replacement, Handlebars: step 1, image 2 of 2
      • Strip all the accessories from your old handlebars. (reflectors, mirrors, etc...)
      • Using a 3/8" Allen wrench, loosen the nuts that hold the brake controls and gear shifters.
      Ask FixBot
    2. Raleigh M20 Handlebars Replacement: step 2, image 1 of 3 Raleigh M20 Handlebars Replacement: step 2, image 2 of 3 Raleigh M20 Handlebars Replacement: step 2, image 3 of 3
      • Place an Allen wrench (size doesn't matter) under the bike grip.
      • Twist the grip back and forth while pulling on the Allen wrench to remove the grip.
      Ask FixBot
    3. Raleigh M20 Handlebars Replacement: step 3, image 1 of 2 Raleigh M20 Handlebars Replacement: step 3, image 2 of 2
      • Slide off the gear shifters.
      • Slide off the brake controls.
      Ask FixBot
    4. Raleigh M20 Handlebars Replacement: step 4, image 1 of 3 Raleigh M20 Handlebars Replacement: step 4, image 2 of 3 Raleigh M20 Handlebars Replacement: step 4, image 3 of 3
      • Loosen the central nut on the faceplate that connects the bars to the steering column. If the bars are secured by a faceplate with a detachable top, loosen the nuts on the faceplate and remove.
      • Lift the handlebars from the bike frame.
      • Move the bars until they're in the correct position for your stance. Tighten the faceplate nuts with a 3/8" Allen wrench to firmly secure the handlebars in place.
      • Sit on the bike and make final adjustments to the positioning of the brakes and gears.
      Ask FixBot
To reinstall the handlebars, complete these steps in reverse order. If there is a problem with the alignment, return to the handlebar repair guide and repeat step 4.
Author
with
Jon Ribera
72 Reputation
1 Guide authored
Cal Poly, Team 7-49, Forte Fall 2012 Member of Cal Poly, Team 7-49, Forte Fall 2012
CPSU-FORTE-F12S7G49
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 102
All Time: 3,000
