Up to 20% off select tools
RYOBI P422 Body Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
95
All Time:
2,213
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. RYOBI P422 Body Replacement, Battery and Handle: step 1, image 1 of 2 RYOBI P422 Body Replacement, Battery and Handle: step 1, image 2 of 2
      • To remove the battery press down on the two buttons located on each side of the battery and pull away from the body of the grinder.
      • To remove the handle hold grinder with one hand and use the other hand to unscrew the handle with a counter-clockwise motion
      Ask FixBot
    1. RYOBI P422 Body Replacement, Body: step 2, image 1 of 1
      • Lay the grinder flat on its side so the screws are facing up.
      Ask FixBot
    2. RYOBI P422 Body Replacement: step 3, image 1 of 3 RYOBI P422 Body Replacement: step 3, image 2 of 3 RYOBI P422 Body Replacement: step 3, image 3 of 3
      • Remove the four 1.8 cm screws from the lower and mid section of the body with the Torx T20 screwdriver.
      • Remove the 3.7 cm screws from the upper section of the body, with the same screwdriver.
      Ask FixBot
    3. RYOBI P422 Body Replacement: step 4, image 1 of 2 RYOBI P422 Body Replacement: step 4, image 2 of 2
      • Now that the two halves are unscrewed, lift up the top half.
      Ask FixBot
    4. RYOBI P422 Body Replacement: step 5, image 1 of 3 RYOBI P422 Body Replacement: step 5, image 2 of 3 RYOBI P422 Body Replacement: step 5, image 3 of 3
      • Remove the safety trigger and the spring.
      • Be careful in removing the safety trigger, the pin may fall out as you are moving it.
      Ask FixBot
    5. RYOBI P422 Body Replacement: step 6, image 1 of 2 RYOBI P422 Body Replacement: step 6, image 2 of 2
      • Lift up main trigger and spring together.
      • By lifting this trigger and spring out of the handle, you will pull double duty by lifting the black switch box off of its two support posts.
      • Slide the trigger off of the black switch box.
      • Be careful when removing trigger, the spring will be compressed and may move unexpectedly.
      Ask FixBot
    6. RYOBI P422 Body Replacement: step 7, image 1 of 3 RYOBI P422 Body Replacement: step 7, image 2 of 3 RYOBI P422 Body Replacement: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Lift the battery lead bracket from its slot.
      • Use the PH 1 screwdriver to unscrew the two 0.7 cm screws that hold the 2.6 cm long brass bracket in place.
      • Use tweezers to remove the brass bracket.
      • During reassembly, remember to keep the spring inside the main trigger and against the bracket that is visible in the second of the accompanying photos.
      Ask FixBot
    7. RYOBI P422 Body Replacement: step 8, image 1 of 2 RYOBI P422 Body Replacement: step 8, image 2 of 2
      • Flip the grinder over and lift off the second half of the body.
      • Now you can replace your damaged handles with a new pair.
      Ask FixBot
2 other people completed this guide.
Author
with
John Lamanuzzi
229 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 95
All Time: 2,213
