Up to 20% off select tools
RYDIS H68 Pro Wheel Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
19
Past 30 Days:
84
All Time:
969
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Wheels not working properly? Follow this guide for steps on how to replace the wheel system on a RYDIS H68 Pro.
    1. RYDIS H68 Pro Wheel  Replacement, Battery: step 1, image 1 of 2 RYDIS H68 Pro Wheel  Replacement, Battery: step 1, image 2 of 2
      • Flip the vacuum over so that the wheels are facing you.
      • Use a Phillips #1 screwdriver to remove the four 10 mm screws that surround the battery cover.
      Ask FixBot
    2. RYDIS H68 Pro Wheel  Replacement: step 2, image 1 of 1
      • Lift the battery cover up to reveal the battery.
      • Remove the battery.
      Ask FixBot
    1. RYDIS H68 Pro Wheel  Replacement, Bumper: step 3, image 1 of 3 RYDIS H68 Pro Wheel  Replacement, Bumper: step 3, image 2 of 3 RYDIS H68 Pro Wheel  Replacement, Bumper: step 3, image 3 of 3
      • Remove the eight 10 mm Phillips #1 screws.
      Ask FixBot
    2. RYDIS H68 Pro Wheel  Replacement: step 4, image 1 of 3 RYDIS H68 Pro Wheel  Replacement: step 4, image 2 of 3 RYDIS H68 Pro Wheel  Replacement: step 4, image 3 of 3
      • Hold the front bumper and pull it off.
      • It requires a lot of force to pull the bumper off.
      Ask FixBot
    3. RYDIS H68 Pro Wheel  Replacement: step 5, image 1 of 3 RYDIS H68 Pro Wheel  Replacement: step 5, image 2 of 3 RYDIS H68 Pro Wheel  Replacement: step 5, image 3 of 3
      • Pry off the back bumper by going around the entire top of the bumper with the metal spudger.
      Ask FixBot
    1. RYDIS H68 Pro Wheel  Replacement, Wheel assembly: step 6, image 1 of 1
      • Remove three 10mm Philips #1 screws that are securing the wheel assembly.
      Ask FixBot
    2. RYDIS H68 Pro Wheel  Replacement: step 7, image 1 of 2 RYDIS H68 Pro Wheel  Replacement: step 7, image 2 of 2
      • Remove the 10mm Phillips #1 screw securing the spring.
      • Then undo the spring from the plastic hook to completely remove it from the wheel assembly.
      Ask FixBot
    3. RYDIS H68 Pro Wheel  Replacement: step 8, image 1 of 3 RYDIS H68 Pro Wheel  Replacement: step 8, image 2 of 3 RYDIS H68 Pro Wheel  Replacement: step 8, image 3 of 3
      • Lift up on the plastic piece to remove the entire wheel assembly.
      Ask FixBot
    4. RYDIS H68 Pro Wheel  Replacement: step 9, image 1 of 3 RYDIS H68 Pro Wheel  Replacement: step 9, image 2 of 3 RYDIS H68 Pro Wheel  Replacement: step 9, image 3 of 3
      • Remove the plastic frame by pulling outward on the two spots where it is fastened.
      Ask FixBot
    5. RYDIS H68 Pro Wheel  Replacement: step 10, image 1 of 2 RYDIS H68 Pro Wheel  Replacement: step 10, image 2 of 2
      • Remove the four 10mm Phillips #1 screws around the edges of the cover.
      Ask FixBot
    6. RYDIS H68 Pro Wheel  Replacement: step 11, image 1 of 3 RYDIS H68 Pro Wheel  Replacement: step 11, image 2 of 3 RYDIS H68 Pro Wheel  Replacement: step 11, image 3 of 3
      • Lift up on the top cover to remove it.
      • Removing the top cover reveals the gear system consisting of three gears.
      Ask FixBot
Author
with
Shawn O'Meara
101 Reputation
1 Guide authored
USFT-Lacy-S17S005G2 Member of USFT-Lacy-S17S005G2
Local Repair Groups
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 84
All Time: 969
