RYDIS H68 Pro Side Brush Motor Replacement
    1. RYDIS H68 Pro Side Brush Motor Replacement, Battery: step 1, image 1 of 2 RYDIS H68 Pro Side Brush Motor Replacement, Battery: step 1, image 2 of 2
      • Flip the vacuum over so that the wheels are facing you.
      • Use a Phillips #1 screwdriver to remove the four 10 mm screws that surround the battery cover.
      Ask FixBot
    2. RYDIS H68 Pro Side Brush Motor Replacement: step 2, image 1 of 1
      • Lift the battery cover up to reveal the battery.
      • Remove the battery.
      Ask FixBot
    1. RYDIS H68 Pro Side Brush Motor Replacement, Bumper: step 3, image 1 of 3 RYDIS H68 Pro Side Brush Motor Replacement, Bumper: step 3, image 2 of 3 RYDIS H68 Pro Side Brush Motor Replacement, Bumper: step 3, image 3 of 3
      • Remove the eight 10 mm Phillips #1 screws.
      Ask FixBot
    2. RYDIS H68 Pro Side Brush Motor Replacement: step 4, image 1 of 3 RYDIS H68 Pro Side Brush Motor Replacement: step 4, image 2 of 3 RYDIS H68 Pro Side Brush Motor Replacement: step 4, image 3 of 3
      • Hold the front bumper and pull it off.
      • It requires a lot of force to pull the bumper off.
      Ask FixBot
    3. RYDIS H68 Pro Side Brush Motor Replacement: step 5, image 1 of 3 RYDIS H68 Pro Side Brush Motor Replacement: step 5, image 2 of 3 RYDIS H68 Pro Side Brush Motor Replacement: step 5, image 3 of 3
      • Pry off the back bumper by going around the entire top of the bumper with the metal spudger.
      Ask FixBot
    1. RYDIS H68 Pro Side Brush Motor Replacement, Side Brush Motor: step 6, image 1 of 1
      • Begin by unscrewing the 2 10mm screws using a Phillips #1 screwdriver.
      • Unlatch the latches indicated. It can be easily done with your finger.
      • Once unsecured, the covering for the sensors can easily be removed allowing access to the sensors.
      • The reason for these first few steps is to avoid damaging the signal wires for the sensor.
      Ask FixBot
    2. RYDIS H68 Pro Side Brush Motor Replacement: step 7, image 1 of 1
      • This step just shows you how everything looks after the previous steps were completed.
      • There are sensors on both the left and right side. This can be done for either side.
      Ask FixBot
    3. RYDIS H68 Pro Side Brush Motor Replacement: step 8, image 1 of 1
      • Unscrew the five 10mm screws using a Phillips #1 screwdriver.
      Ask FixBot
    4. RYDIS H68 Pro Side Brush Motor Replacement: step 9, image 1 of 1
      • The side brush motor can now be removed by lifting it up.
      Ask FixBot
jude auguste
108 Reputation
1 Guide authored
USFT-Lacy-S17S005G2 Member of USFT-Lacy-S17S005G2
Local Repair Groups
4 Members
59 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 23
Past 30 Days: 71
All Time: 1,021
