RTX 3070 VENTUS 2X OC GPU FAN Replacement
    1. RTX 3070 VENTUS 2X OC  GPU FAN Replacement, Grab your tools and prepare: step 1, image 1 of 1
      • Clear your workspace to prevent screws from going missing.
      Ask FixBot
    2. RTX 3070 VENTUS 2X OC  GPU FAN Replacement, Remove GPU shroud: step 2, image 1 of 2 RTX 3070 VENTUS 2X OC  GPU FAN Replacement, Remove GPU shroud: step 2, image 2 of 2
      • Remove the screws that are holding your shroud in place(may differ from card to card)
      Ask FixBot
    3. RTX 3070 VENTUS 2X OC  GPU FAN Replacement, removal of shroud: step 3, image 1 of 1
      • Remove shroud from heatsink
      • Be careful of fan wires when removing shroud
      • In some models the fan are screwed into the heat sink. In those models just remove the shroud for easy access to the fan
      Ask FixBot
    4. RTX 3070 VENTUS 2X OC  GPU FAN Replacement, gpu fan cable: step 4, image 1 of 2 RTX 3070 VENTUS 2X OC  GPU FAN Replacement, gpu fan cable: step 4, image 2 of 2
      • Remove the gpu cable and it leave behind the bare heatsink
      Ask FixBot
    5. RTX 3070 VENTUS 2X OC  GPU FAN Replacement, Fan screw: step 5, image 1 of 2 RTX 3070 VENTUS 2X OC  GPU FAN Replacement, Fan screw: step 5, image 2 of 2
      • Remove the screws that are holding the fans in place
      Ask FixBot
    6. RTX 3070 VENTUS 2X OC  GPU FAN Replacement, Fan removed: step 6, image 1 of 2 RTX 3070 VENTUS 2X OC  GPU FAN Replacement, Fan removed: step 6, image 2 of 2
      • Get your replacement fan and reverse the order for reassembly.
      Ask FixBot
2 other people completed this guide.
fareast00
181 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 58
Past 30 Days: 236
All Time: 9,296
