ROYALAXE R68 TKL Key Switches Replacement
    1. ROYALAXE R68 TKL Key Switches Replacement, Key Switches: step 1, image 1 of 2 ROYALAXE R68 TKL Key Switches Replacement, Key Switches: step 1, image 2 of 2
      • Unplug the keyboard from its power source.
      Ask FixBot
    2. ROYALAXE R68 TKL Key Switches Replacement: step 2, image 1 of 1
      • Remove all keycaps with the keycap puller.
      • You can line up the keycaps in order or take a picture of your keyboard to make it easier to put them back on at the end.
      Ask FixBot
    3. ROYALAXE R68 TKL Key Switches Replacement: step 3, image 1 of 2 ROYALAXE R68 TKL Key Switches Replacement: step 3, image 2 of 2
      • Clean the keyboard using a compressed air duster and a small brush or cotton swab.
      • You can also clean your keycaps by soaking them in a bowl with water and soap for about 30 minutes.
      Ask FixBot
    4. ROYALAXE R68 TKL Key Switches Replacement: step 4, image 1 of 2 ROYALAXE R68 TKL Key Switches Replacement: step 4, image 2 of 2
      • Remove the switches with the switch puller.
      • Make sure to clamp on the switch vertically instead of horizontally. Then gently pull it out.
      • Taking out the switch by pulling horizontally could damage the switch.
      Ask FixBot
    5. ROYALAXE R68 TKL Key Switches Replacement: step 5, image 1 of 3 ROYALAXE R68 TKL Key Switches Replacement: step 5, image 2 of 3 ROYALAXE R68 TKL Key Switches Replacement: step 5, image 3 of 3
      • Make sure the copper part of the switch faces you when you try to insert the switch.
      • Insert the key switch as straight as possible and press down gently until you hear a click.
      • If you fail to line it up, it will bend the copper part under the switch. This will permanently damage the switch.
      Ask FixBot
    6. ROYALAXE R68 TKL Key Switches Replacement: step 6, image 1 of 2 ROYALAXE R68 TKL Key Switches Replacement: step 6, image 2 of 2
      • Place keycaps in their respective position.
      • Make sure all keys are operating well.
      • Enjoy your new switches!
      Ask FixBot
Finish Line
2 other people completed this guide.
Angie
199 Reputation
1 Guide authored
1 Guide Comment
Hey! This was very helpful, thank you for making it! Now if we could get one that is focused on battery replacement 😆
Tom Mclaughlin - Reply Share
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 42
All Time: 977
